Page 389 of 651 FirstFirst ... 289339379387388389390391399439489 ... LastLast
Results 3,881 to 3,890 of 6510
Thread: Golf R Observations and Questions
  1. #3881
    Jan 2011
    VIC
    Quote Originally Posted by Corey_R View Post
    Well, I'd hardly say that it's "taking" anything It's just that Big_Dave isn't able to use the benefits of the R to overtake the XR5... catch, but then not overtake....
    Bull****. Car should be zipping past the xr5 on the straight no worries.
  2. #3882
    Sep 2011
    Gold Coast, Qld
    A couple of questions then.
    What is different between the GTi motor & the R donk? I see the compression is slightly more and heard something about a steel timing chain??? Is the bottom end the same?
    Also has anyone been able to log the torque split with the haldex unit thru various situations? I read somewhere it can split up to 100% rear which is good Pity there is no manual overide to lock in what you want, but anyway...What ratio is straight line for instance at a constant 100km for example.
    Also regarding oil changes has anyone bothered to do a 6 monthly change themselves?
    Cheers Paul
  3. #3883
    It's all to the front if there's no slip detected/no output from the stability control, that's how I understand it.
    EDIT
    Not quite zero to the rear. Cut from the Wiki:
    The XWD system can transmit 100 percent of available torque to either the front or rear wheels. However, for those conditions to occur one end of the vehicle would have to lose all traction, like driving on ice for instance. During a standing start the rear wheels are put to use, without the need for any slip to occur. Then under straight-line cruising conditions, to conserve fuel and driveline wear, the torque split to the rear wheels is reduced to a level between 5 and 10 percent. Also up to 85 percent of torque can be transferred by the eLSD between to any single rear wheel if necessary. The system can adjust torque splits based on calculated conditions, such as those that indicate an aggressive lane change manoeuvre, to effectively reduce oversteer or understeer without any wheel slip occurring. In the event that some wheel slip does actually get to occur, the system can react more timely and efficiently than in the past. [6]
  4. #3884
    Sep 2011
    Gold Coast, Qld
    So it's a SAAB XWD unit then ???
  5. #3885
    Sep 2011
    Gold Coast, Qld
    Cheers Gavin
    Any others for my other questions?
    One more thing as well, I haven't read anything about it but is there any variable cam timing? I'm thinking not as haven't seen it mentioned in the tuning section either.
  7. #3887
    Feb 2009
    Sydney, Australia
    You'll find more information if you research EA888 and EA113.
    EA888 is the engine series in the MK6 GTI. EA113 is the engine series in the MK5 GTI and MK6 Golf R (as well as Audi S3).
    The EA888 is a total new design and not a progression of the EA113.
    Additionally, there are internal differences between the EA113 used in the K03 turbo based engines (MK5 GTI) and K04 turbo based engines (MK6 R and S3).
    In relation to the variable cam timing, some of the Audi versions of the EA888 have what they call "Valve Lift" which gives 350Nm instead of 280Nm from the non valve-lift versions. I'm not sure if that is the type of thing you're asking about though.
  8. #3888
    Sep 2011
    Gold Coast, Qld
    Cheers for that.
    Is the valve lift variable, in that it is tuneable? I ask as there where significant gains to be had with the cam timing in the subarus.
    Edit: According to wiki it has variable intake cam adjustment - http://en.wikipedia.org/wiki/List_of...petrol_engines
    A question for the tuning section then.....
  9. #3889
    Sep 2011
    Gold Coast, Qld
    Golf R MY10, - MY12, which build date defines what?
    I've searched here & google to no avail. What build dates define MY10, MY11, MY11.5 & MY12 for the Golf R?
  10. #3890
    Jan 2008
    Lower North Shore
    Hey there. Mine is 11.5 and KZB. So i think it has been decided.
    KZA my10
    KZB my11
    KZC my12
    In Carport. R
