Can anyone explain as to why the Golf R has the turning circle of a bus?? My old mans 1988 300SE Merc has a better turning circle,not joking!
VIEZU TUNE| APR IC| MTM CATBACK| TURBOXS DOWNPIPE| HPFP FUEL PUMP| FORGE TWINTAKE CAI|
KW DDC COILOVERS| WHITELINE BUMPSTEER KIT| WHITELINE SWAYBAR LINK ENDS| H&R SWAYBARS|
SUPERPRO ALLOY ARMS| UNIBRACE UB| HPA DOGBONE MOUNT| REVOZPORT CARBON MIRRORS & GRILL|
GARAGE VARY CARBON DIFFUSER| TEKARBON CARBON BATTERY & FUSE COVERS| P3 GAUGE| VOLK VRG2|
Most big Mercs have front wheels that adjusts the camber as it turns at low speeds which isn't unlike how a bike corners. That's what gives it a tighter turning radius.
The 4WD gear seems to cause this large turn circle. Ditto with my Evo. That was always a gamble. I ended up avoiding u turns on major roads. In case I had to do a 3 point turn.
Dont they have limiters when 19s are fitted ?
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
Yeah... the only people who complain about the R's turning circle are the boys on 19" rims. They're wider than any other Golf rim and I think VW have gone a bit conservative in ensuring that it won't scrape the inside of the wheel well or something. The R's turning circle isn't significantly worse than any other small/medium car I've owned or used... otherwise I wouldn't be able to get out of the tight spot at work where cars like Ford F6E's etc need to do 3 point turns. lol
I have 19s and noticed the turning circle was a bit larger than expected, I am used to it now though. What is this limiter you speak of? I have been thinking of changing to 18" rims (I only got 19s for the black headlights anyway), is there something that needs setting to change this limiter?
RB Golf R doesnt have this problem
