Hmmm,
doesn't seem to stay on in mine.
I often sit in car waiting to pick up kids etc, and I like to charge phone.
But it appears that as soon as i turn off ignition, power from 12v outlet stops also, and doesnt reconnect unless I turn key to last position.
I will have another look at it, maybe it is a VCDS adjustment?
what you says does make sense as power to windows and radio stays on, go figure?
What WOULD I do without Watercooled.
Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
Touareg V8 TDI R-Line, White .Arrived 11 July.
Only if you're enabled it via VCDS, and the car is locked, and the windscreen wipers set to auto, and the rain hits the rain sensor on the windscreen
Well, that's what my lowly Skoda does. I figured it was a universal VW thing.
Silverfish: They should be auto but
a) you have to set it up via the MFD in the dash
b) (IIRC) the wipers have to be on (like the intermittent setting or better)
c) there's some time factor involved which totally escapes me.
Mine have played nice most of the time but sometimes the windows stay down for no obvious reason.
lol fair point
I'm using 12v as I am waiting on my MDI extension lead to arrive. Then I will have my phone above console and on MDI.
Ok, another observation.
The daytime running lights have two intensity.
Bright when other lights are off, less bright when Mains are on.
Never noticed before.
Also you can dim them during the day by turning Parkers on.
I'm pretty sure my DRL's turn off when the main lights come on (auto) (can see the reflection when stuck in traffic in a tunnel), plus I've seen it happen on some other Golf's coming the other way. Golf R might be different I guess, or maybe it's a Xenon/LED thing.
