I should check this, but if you turn the headlight switch all the way to the right, and pull it out one notch, doesn't that turn on the "park" lights which is what these are?
That's the like which was originally intended to be the DRL.
However, the MK6 Xenon headlight was a case of form over function, as it turned out to be too small and not bright enough. Hence why GTI's ended up having their Xenon as the DRL and the R got a LED Stripe.
no... that turns on the rear fog light...
Anyone else noticed that the exhausts open up after a couple thou k's?
Initially, only one flap was open at idle/startup (didn't check it after hard driving), but now i've broken it in a bit, both flaps/exhausts are open all the time.
Makes the exhaust sound much deeper (which others have also reported) but makes me question what the flapper mod was all about though?
It is a port to the drivers side of the coin holder in the armrest and it has a cable attached which allows you to connect a usb device. wont work with IPhone, you need a different cable, but VW spare parts sell them.
I notice Halo also had chosen Bluetooth, so I wonder if it has something to do with the Factory having to install BT. maybe they have to do MDI if you request BT, and they dont mention it knowing that most buyers will probably select both options anyway.?????
I wonder if Dermot can confirm?
Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
Touareg V8 TDI R-Line, White .Arrived 11 July.
I've also asked the service advisor & service manager at Barloworld and they never knew this light existed lol....
I would be very interested to change the LED DRLs on the R to a brighter and whiter one (similar to Audi's) when an aftermarket one comes out.
I dislike the yellowish colour of the current one.
| Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
