Page 270 of 651 FirstFirst ... 170220260268269270271272280320370 ... LastLast
Results 2,691 to 2,700 of 6510
Thread: Golf R Observations and Questions
  1. #2691
    Feb 2009
    Sydney, Australia
    That's the like which was originally intended to be the DRL.
    However, the MK6 Xenon headlight was a case of form over function, as it turned out to be too small and not bright enough. Hence why GTI's ended up having their Xenon as the DRL and the R got a LED Stripe.
  2. #2692
    Nov 2009
    I should check this, but if you turn the headlight switch all the way to the right, and pull it out one notch, doesn't that turn on the "park" lights which is what these are?
  3. #2693
    Feb 2009
    Sydney, Australia
    no... that turns on the rear fog light...
  4. #2694
    Nov 2009
    Anyone else noticed that the exhausts open up after a couple thou k's?
    Initially, only one flap was open at idle/startup (didn't check it after hard driving), but now i've broken it in a bit, both flaps/exhausts are open all the time.
    Makes the exhaust sound much deeper (which others have also reported) but makes me question what the flapper mod was all about though?
  5. #2695
    Nov 2009
    Quote Originally Posted by Corey_R View Post
    Ahh, second notch out on the Tiggy was the rear fogs, and first notch is front fogs, but haven't actually checked to see what it does on the R yet.
  6. #2696
    Quote Originally Posted by DDTW View Post
    Wow! I didn't order MDI and sure cant see any cables dangling in the centre arm rest console....
    Where is this cable attached to?
    It is a port to the drivers side of the coin holder in the armrest and it has a cable attached which allows you to connect a usb device. wont work with IPhone, you need a different cable, but VW spare parts sell them.
    I notice Halo also had chosen Bluetooth, so I wonder if it has something to do with the Factory having to install BT. maybe they have to do MDI if you request BT, and they dont mention it knowing that most buyers will probably select both options anyway.?????
    I wonder if Dermot can confirm?
    Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
    Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
    Touareg V8 TDI R-Line, White .Arrived 11 July.
  7. #2697
    Quote Originally Posted by Big_Dave View Post
    Guys,
    am looking for some good websites for wheels that will fit R.
    I have trolled wheels pic thread but little info on where to look for wheels.
    All the local tyre places look at me with blank expressions when I mention its a VW. lots of options for Commodes and Falcoons.
    Is offset 45?
    FWIW I am looking for a 18" wheel predominately in red and black.
    Corey, feel free to move this if required?
    C'Mon guys, please share where you are buying all these great wheels from?
    Have tried tirerack
    * and yes I am an impatient Bastard.
  8. #2698
    Nov 2010
    Melbourne, VIC
    Haha that's MDI for sure! They must have accidentally installed it! Lucky you!
    I have BT but no MDI. More than happy with the SD Card =)
    | Golf R MY11 | DSG | 3 Doors | RB | Recaro | 19" Talladegas | ACC | Sunroof | BT | APR S1 | APR Carbonio | MillteK Sport CBE |
  9. #2699
    Nov 2010
    Melbourne, VIC
    I've also asked the service advisor & service manager at Barloworld and they never knew this light existed lol....
    I would be very interested to change the LED DRLs on the R to a brighter and whiter one (similar to Audi's) when an aftermarket one comes out.
    I dislike the yellowish colour of the current one.
  10. #2700
    Nov 2009
    Quote Originally Posted by Glennb View Post
    The Golf R doesn't have front fogs, so presumably the switch only pulls out one notch. Current cars equipped with front and rear foglights have a switch that operates as per your Tig.
