Page 227 of 651 FirstFirst ... 127177217225226227228229237277327 ... LastLast
Results 2,261 to 2,270 of 6510
Thread: Golf R Observations and Questions
  1. #2261
    Jan 2011
    NSW
    Theres puddles but they arent water
    Clear/clean oil
    Looking underneath the car theres quite a bit of oil around , I'll try post a picture soon.
    Only just discovered it this morning
  2. #2262
    check that ur oil filter is on properly!
    84 MK1 GTI
    01 DC2R
  3. #2263
    Nov 2006
    Canberra, Australia
    FYI, Oettinger & APR no longer share any financial involvement, Oettinger have new Owners & are continuing along their own development path. They have their own engineers / calibrators & development facility.
    The warranty is a big part of the product (and considerable component of the cost).
    Thanks for the update Guy.
    MY10 S3 3dr
  4. #2264
    Jan 2010
    Springwood
    Good call BY,
    Wouldn't be the first time that has happened during a service.
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
  5. #2265
    Jan 2011
    NSW
    Thanks for the quick responses
    i shall check the oil filter this evening
    Am i right in thinking the oil filter is located on the bottom side of the engine (behind the plastic coverings?) and accessed from underneath?
  6. #2266
    Jan 2010
    Springwood
    I doubt many R owners have had reason to change a filter yet.
    Might be worth asking some MKV Pirelli owners, given they run the same engine...
  7. #2267
    the oil filter is covered by a black plastic cover (same shape as filter) an has a large hex nut on the top of it. u need to take that off to get to the filter. from memory it was located at the front of the engine?
    84 MK1 GTI
    01 DC2R
  8. #2268
    Erskineville, NSW
    Quote Originally Posted by pumped View Post
    Has anyone that owns a Golf r experienced an oil leak?
    Notably after first checkup/service, prior to this there were no issues
    Any ideas what could cause there/if there any easy fixes?
    1) dirty mechanic didn't clean up spillage.
    2) didn't replace the crush washer / sump plug correctly or didn't tighten properly or over-tightened & cracked the sump.
    3) incorrect replacement of oil filter. left the 0-ring in place & put another on top; didn't tighten the drain properly, etc.
    not much else to stuff up really.
  9. #2269
    We have seen a couple of R's with that sort of oil leak, after cleaning it up & running them, they appear to be weeping around the main sump line. This is a sealant joint.
  10. #2270
    Nov 2010
    ah yes, this is something my mechanic had advised me of prior to purchasing my R.
    MY11 Reflex Silver Golf R DSG / Mitsubishi Evolution MR
