check that ur oil filter is on properly!
Theres puddles but they arent water
Clear/clean oil
Looking underneath the car theres quite a bit of oil around , I'll try post a picture soon.
Only just discovered it this morning
84 MK1 GTI
01 DC2R
Good call BY,
Wouldn't be the first time that has happened during a service.
2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
Thanks for the quick responses
i shall check the oil filter this evening
Am i right in thinking the oil filter is located on the bottom side of the engine (behind the plastic coverings?) and accessed from underneath?
I doubt many R owners have had reason to change a filter yet.
Might be worth asking some MKV Pirelli owners, given they run the same engine...
the oil filter is covered by a black plastic cover (same shape as filter) an has a large hex nut on the top of it. u need to take that off to get to the filter. from memory it was located at the front of the engine?
84 MK1 GTI
01 DC2R
1) dirty mechanic didn't clean up spillage.
2) didn't replace the crush washer / sump plug correctly or didn't tighten properly or over-tightened & cracked the sump.
3) incorrect replacement of oil filter. left the 0-ring in place & put another on top; didn't tighten the drain properly, etc.
not much else to stuff up really.
