Page 226 of 651 FirstFirst ... 126176216224225226227228236276326 ... LastLast
Results 2,251 to 2,260 of 6510
Thread: Golf R Observations and Questions
  1. #2251
    Apr 2010
    Melbourne, Australia
    Quote Originally Posted by DeanCorp View Post
    and can you get an Evoms intake while your at it. I want to see how it compares to Fab_R's, same car, different exhaust and one is manual one is DSG. This will be interesting
    Hey Dean...I dont hold too much faith in my dyno results given andret's results here.
    Im going to get another dyno run in elsewhere in the very near future...
  2. #2252
    Apr 2009
    Quote Originally Posted by andret View Post
    totally correct fab_r - dyno's reading are all different - all I'm interested in is seeing the gains - I unfortunately didn't get to dyno the stock car. I wouldn't be concerned about dynoing if you've already proved a 0-100 4.26 sec (was that on vbox or something similar)
    Nope was not on a vbox..Let's not start this up again..
    There is nothing wrong with RE Customs Dyno.
    Andret what I would suggest is you go and get another dyno run elsewhere just using rollers as it seems a little high. But then again it could be the different exhaust that has made the difference over Fab_R's setup.
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
  3. #2253
    May 2010
    Hey Andret,
    This looks awesome!! Very nice bit of kit. Costs around?
    And was that on a roller dyno or a HUB? (HUB obviously read out higher! If not thats some pretty good numbers there fella..
    Nice Pics!
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  4. #2254
    Oct 2010
    Canning Vale, WA
    Quote Originally Posted by REXman View Post
    +1. Really does look awesome!
  5. #2255
    Aug 2007
    Quote Originally Posted by Corey_R View Post
    You mean like this?
    Dyno Results
    APR 1 Without custom exhaust
    (189KW)
    APR 1 with custom exhaust
    (192KW)
    So the exhaust is just for sound and looks? I would have expected much more than 3KW gain...
  6. #2256
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by chylld View Post
    Most "Cat-back exhausts" (which don't replace the cat, btw) are just for sound and looks! On modern turbo-based cars, most of the cars to be had are in the downpipe (which is connected directly to the turbo) and the catalytic converter with a "high flow" or "motorsports" version. The cat is replaced with the downpipe - sometimes called a front pipe or dump pipe.
    Once the downpipe is replaced, you can then also run a Stage II turn. In any case, the peak power is still not a big jump. But since back pressure on the turbo is reduced, spool times improve and come at lower RPMs and the power band is widened.
  7. #2257
    Aug 2007
    Thanks for that Corey
  8. #2258
    Jan 2010
    Springwood
    3Kw is peak.
    The DP should improve spooling, and midrange may be lifted too.
    There are other factors like throttle response too, which may improve driving experience, but not reflect on a dyno.
    (edit: oops, seems corey beat me to it, need to refresh before i start typing)
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
  9. #2259
    Jan 2011
    NSW
    oil leak
    Has anyone that owns a Golf r experienced an oil leak?
    Notably after first checkup/service, prior to this there were no issues
    Any ideas what could cause there/if there any easy fixes?
  10. #2260
    Aug 2007
    Quote Originally Posted by pumped View Post
    i'm assuming you're seeing some puddles on your garage floor... it might just be AC condensate. dip your finger in it and see if it's clear
