Page 210 of 651 FirstFirst ... 110160200208209210211212220260310 ... LastLast
Results 2,091 to 2,100 of 6510
Thread: Golf R Observations and Questions
  1. #2091
    May 2009
    Perth, WA
    Quote Originally Posted by DDTW View Post
    Ooh boy I'd like that exhaust flap button mod!
    Talking of flapper mods, has anyone done it to their R yet?
    MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
    MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
  2. #2092
    Apr 2010
    Melbourne, Australia
    Feb 2010
    Fab_R, don't get me wrong, I am all for sharing the vids but just wondering if nanny state (VIC) cops can actually came after you for "hooning" based on the vids.
    2011 Mk6 GTI | CW | DSG | Bi-Xenon | GIAC | APR TBE | THS FMIC | Modshack
  4. #2094
    Jul 2010
    Fab_R...nice vids...
    i see you went to RE for ur dyno runs...
  5. #2095
    Apr 2010
    Quote Originally Posted by crazyray View Post
    Hey Ray correct mate. Results up shortly by Dave_R.
  6. #2096
    Nov 2009
    Not at work so don't have a scanner handy this time, dodgy photos will have to do for now...
    This is an overlay of my original graph with the new run.
    A new run against RPM instead. This was the 3rd or 4th run so one thing I've noticed is that the power is consistent.
    And finally my original and updated runs, with Fab's run included, power and torque (tractive effort) shown.
    The Stage 1 tune has an improvement but IMO, APR's claims are slightly misleading. I'm not interested in peak numbers, but was hoping for more power much earlier.
    Quote Originally Posted by APR Website
    Not only does our Stage I ECU Upgrade give you higher peak numbers of 239kw and 435nm. Gains of up to 49kw are available at lower rpms!
    There are no gains until well past 4000 rpm, or our idea of lower rpms are different? Maybe the fuel pump is needed to get much lower rpm increases but it isn't listed as a required upgrade let alone recommended?
    Fab's stage 2 tune however isn't really fairly represented by the graph. While the difference early in the rev range isn't huge, the driving experience is vastly different. His car has so much better response and urgency at lower rpms. So looks like frontpipe and fuel pump are gonna have to get added in....
    I had VCDS logging things on my runs but haven't looked at the logs yet. Didn't get around to doing any on Fab's car though.
    But for a real world comparison... the stage 1 R still doesn't have enough go to beat an RS5 from 80 on the run lol. Could still stay within a car length but there is no shame in being beaten by such a sweet sounding V8 reving to 8000rpm
  7. #2097
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by dave_r View Post
    Yeah, I've sent a PM to Guy_H about this one because in the copying and pasting of the marketting blurb from the K03 engine-based upgrade page, they've forgotten to change the "lower rpms" to "higher rpms" such as what it is on the USA page of the same ECU upgrade. I'm surprised that no one has picked that up in all these years...
    In any case, the engine dyno plot they provide visually shows what to expect.
    Quite frankly though, your results are the lowest results I've ever seen for a stage 1 tune (including other APR stage 1 tunes) on this engine. I'm presuming that this is the same dyno - what were the environmentals like for this day?
    Your original run of 149kw was good (maybe too good?), so to see an increase to only 164 to 167kw is not expected.
    As for the no increases until 4000rpm. There should be small increases in power with this turbo/engine combination. But the major increases in that range are the torque, which should show increases over the entire rev range. Your dyno graphs don't do torque though (except for maybe that last one, but it's a bit messy and confusing).
    You are correct though, if you want to significantly increase power and torque lower in the rev ranges you must change the downpipe. The downpipe is what allows the lowering of the rpm's at which the turbo spools up. The fuel pump allows for additional fuel in the mid rpm range where there is not enough revs to operate the pump fast enough to provide fuel with the stock pump.
    If you are not concerned about peak numbers and your objective is lots of power and torque low in the revs, I'm sorry, but you've picked the wrong car! The GTI with it's K03 turbo is much better suited to lower revs (but then runs out of puff at the peaky end of the rpms!).
  8. #2098
    May 2009
    Perth, WA
    I've just finished washing the R and noticed that the far right hand side of the gloss black rear diffuser doesn't seem to sit as flush as the left hand side, also due to this the red reflector also sits a lot further in at the right hand side pointy end than the left hand side. Anyone else have this on their car?
  9. #2099
    Nov 2009
    Quote Originally Posted by Corey_R View Post
    Well the page clearly indicates Golf R and the dyno graph (ignoring the numbers) shows a visiable improvement throughout the rev range.
    Temps etc were around the same and the car was strapped down/operated by the same person so there isn't much variation there.
    Again irrelevant as the APR claims talk about kw's - Gains of up to 49kw are available at lower rpms! Forget 49kw, I don't see even half or a 1/4 of that at lower rpms. Unless "lower rpms" is 5500 instead of 6000?
    I picked the right car, but it seems the info out there is incorrect and slightly misleading? I'll take up the point with the relevant people tomorrow, just thought I'd put it up here for discussion as I knew people were interested in the results.
  10. #2100
    Feb 2009
    Sydney, Australia
    As I said before, the word "lower" is a mistake and should be "higher", and I've PM'd Guy to let him know that needs to be corrected.
    Everything else on the page is correct as far as I can tell, including the dyno graph which clearly shows that the increase of 49kw is at 6700rpm. So whilst there is a wording mistake, the information on the graph is correct - hence, why I said, I'm surprised no one has noticed the mistake before.
    For example, have a look at the USA version of the page. It has the correct word of higher instead of lower. But also compare the PEAK figures of Stage 1 vs Stage 2+ on 98 octane fuel.
    There only 7hp difference.
    So what I'm saying is that at the pointy end of the dyno runs that you and Fab did, there should only be a small difference, and yet there isn't.
    The dyno runs I've seen previously of the APR Stage 1 flash on this engine are around the 188kw range. Stage II and Stage II+ gives you a wider power band (i.e. the torque and power comes up much quicker, lower in the RPMs). So I'm curious to know what is holding your car back...
