Page 166 of 651 FirstFirst ... 66116156164165166167168176216266 ... LastLast
Results 1,651 to 1,660 of 6510
Thread: Golf R Observations and Questions
  1. #1651
    Apr 2010
    How fast do you drive around (or out of) a roundabout anyway - I've been able to go round them in 3rd gear without problematic power/lag issues
  2. #1652
    Apr 2010
    Melbourne, Australia
    Quote Originally Posted by triode12 View Post
    It is not about a having heavier right foot...even if you stomp on the throttle, the built-in delay still prevents the car being as responsive as one would like/expect it to be.
    I gotta say, i'm interested!!
  3. #1653
    From their own website:
    How It Works
    Sprint Booster modifies the signal between the accelerator pedal module and the electronic throttle body. This modified signal forces the throttle body to open 'more' than the stock signal at a given pedal position. In effect, the idle-to-full-throttle pedal travel is reduced. This makes your car 'feel' more powerful because a given pedal input produces greater throttle opening. This is especially evident in the low to mid rpm range where most cars spend their time on the street.
    Sprint Booster simply modifies the throttle signal between the accelerator pedal and the throttle body. Big deal right? Keep in mind, this is the same concept as the 'throttle pulley' modification on cable based throttle systems - which was very popular in it's time. It doesn't add horsepower, but makes the throttle more sensitive and makes the car 'feel' faster.
    Is Sprint Booster for everyone? Of course not, no performance product ever is. If you have a track car where you spend most of your time near redline, Sprint Booster is not for you - Sprint Booster benefits are felt in the low to mid pedal travel. Some people don't like the fact that Sprint Booster reaches full throttle before full pedal travel - if you routinely mash the throttle to the floor, Sprint Booster may not be for you.
    An On/Off switch for throttle? Sounds like oil of the serpent to me
  4. #1654
    Apr 2010
    Yeah I had a look and don't see any point to it now that I'm APR'd
  5. #1655
    Apr 2008
    NSW
    Hey guys
    Given the previous problems the MKV had with PCV's and cam followers and what have you, I've decided to take precautionary measures to make sure the MK6 doesnt suffer the same fate
    So I've decided to change to :
    1) OEM Revision "D" Piston DV (if it doesnt have one already)
    2) Buy the 2.0 TFSI cam follower and have it ready just in case it craps itself.
    3) OEM Revision "F" PCV Revision with EuroJet PCV tubing
    4) Oil Catch Can
    Now, #4 is where I need assistance and advice. I'm planning on installed an Oil Catch can but I dont know which one is best. Well, maybe best is a poor choice of word but I just want to know which one most people use and recommend?
  6. #1656
    May 2009
    Quote Originally Posted by Pepe View Post
    When I mash the accelerator pedal on both my golfs(one is a GT with a 1.4 TSI engine - with a small supercharger for boosting the low revs) - there is still a 1/2 sec delay before anything happens. The delay has nothing to do with lag.
    So I don't believe the small amount "lag" that BezzyR is experiencing post APR is due to lag but rather the throttle delay.
    There is a sprintbooster dealer in Australia - I'm sure one could always ask for a trial before purchase.
  7. #1657
    Dec 2010
    NSW
    The device is a couple of resisters in parallel that helps eliminate the electronic delay, a side-effect with all drive-by-wire throttles. It's not meant to be magic, but a practical electronic fix... I have one on my 6MT Porsche & I wouldn't have it any other way, makes heal & toe so much easier!
    Sprintbooster will help (not eliminate) the dreaded R lag issue IMO, why? because it will send the throttle single to 2500rpm quicker than stock thus sending the turbo to spool earlier. The sooner the turbo spools the less lag...
  8. #1658
    Nov 2009
    Hills District, Sydney, NSW
    I am not convinced, the documentation indicates it has absolutely no performance improvement abilities whatsoever. My conclusion is it merely changes the distance required to obtain throttle response, so rather than having to flatten the foot pedal to achieve the desired response from the engine it it just further up the throttle depression arc. Hence why it has no value on the track however may improve the feel of the car when driving about town because you dont have to be so dramatic when trying to get the car to respond.
    It is a driving experience rather than a performance enhancing device.
  9. #1659
    May 2009
    Quote Originally Posted by SilvrFoxX View Post
    You have no argument from me about that. The device manufacturer also states that it doesn't improve performance.i.e. doesn't add hp or kw.
    But isn't improving the driving experience of any car important?
  10. #1660
    Dec 2010
    NSW
    I won't increase power if that's what you consider "performance improvements" it will however improve driveability especially in manual transmission, similar to "sports mode" with a remapped throttle response found in high-end German sports cars without increasing the power!
