Page 119 of 651 FirstFirst ... 1969109117118119120121129169219619 ... LastLast
Results 1,181 to 1,190 of 6510
Thread: Golf R Observations and Questions
  1. #1181
    Feb 2009
    Sydney, Australia
    I don't believe that Xenon's are any more susceptible to shortened life spans from being turned on or off than traditional headlights (and certainly the wiki doesn't mention this either). Xenon's are backed up by halogens for "flashing" not because of reduced life, but because Xenon's take too long to "warm up" and therefore cannot be used for "flashing".
    Xenon's last much longer than Halogens, between 2 and 4 times longer, depending on the types of globes being compared. But yes, Xenon's are significantly more expensive to buy - especially in Australia where supply is not that great. You're best to purchase ahead of time and import from Europe or the USA (Europe is probably better, since the USA is not a huge user of Xenons either). But with 2000 hour average service life, you probably wouldn't need to do that for quite some time yet....
  2. #1182
    Betoota
    Are you certain that this is correct?
  3. #1183
    Feb 2009
    Sydney, Australia
    May not be the case with the MK6. I don't have mine yet!
  4. #1184
    Betoota
    The flash to pass halogens have been removed from the bi xenon's in the Mk6 which is one option I miss from the Mk5. One option I like is the ability to play audio from your iPhone through the stereo via bluetooth as it makes selecting songs faster. I'm lucky to use 7% of the phones battery when playing music via bluetooth for an hour.
    Has anyone else found that the Dynaudio can be buggy as my unit has rebooted itself and also has became unresponsive on a few occasions?
  5. #1185
    Mar 2010
    Witness Protection
    Quote Originally Posted by HPSOV View Post
    Question about Xenon headlights.
    My drive to work involves tunnels and underground carparks. In each direction the auto headlights turn on and off 7 times. That's 70 times a week plus any weekend driving. Will this reduce the life of the globes? Should I just turn auto off? Are the globes expensive to replace if they do blow?
    Xenons "are estimated to last more than one thousand ignitions." - read into that what you want.
    Source Xenon Bulbs
  6. #1186
    Jul 2010
    Perth
    Quote Originally Posted by Icarus View Post
    Mine works flawlessly...
  7. #1187
    Sep 2009
    Perth, WA
    Dynaudio is just an 8-way amp and some speakers. The fault is more likely to be in your head unit.
    GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
  8. #1188
    Betoota
    I was hoping that the various issues are addressed in a firmware revision.
    I don't want the dash pulled apart to replace the RNS510.
  9. #1189
    Jul 2010
    BrisVegas
    Can someone with a golf r in possession elaborate on the foam usage in the enginebay?? All the cars I have seen have foam where bonnet rests when closed... Still there post delivery?
  10. #1190
    Jul 2010
    BrisVegas
    Another question, can you put roofracks on a 3 door golf? Normally the supports sit under door seals on 5 door... Don't think this would work on 3 door...
