Page 651 of 651 FirstFirst ... 151551601641649650651
Results 6,501 to 6,510 of 6510
Thread: Golf R Observations and Questions
  1. #6501
    Jun 2021
    Wollongong NSW
    Thanks for your knowledge
    Golf Mk6 R
  2. #6502
    Jun 2021
    Wollongong NSW
    Sorry for the Double post on the timing Belt..I need to know about the OBDEleven scanning for Timing Belt stretching as in can be used for Timing Chain Stretch..Is this doable and How
    cheers
    Golf Mk6 R
  3. #6503
    Quote Originally Posted by GolfR64 View Post
    cheers
    Timing belts snap or break apart, whereas timing chains stretch and can potentially snap but its rare.
    If you are worried about the condition of your timing belt, remove the cover and give it a good visual inspection. Look for cracking and other deterioration.
    Timing belts are recommended to be changed every 5-6years or 105,000km. Its about $1k to change the timing belt (parts, tensioners, water pump and labour) but if it snaps it will cost you a lot more than $1k.
    Given your car is 11yrs old with 150,000km you should be currently on your 2nd timing belt and getting close to replacing it again shortly.
  4. #6504
    Jun 2021
    Wollongong NSW
    Yeap it Due in 2025 . Second belt was done in 2018
    Thanks for the info
    Golf Mk6 R
  5. #6505
    Jun 2021
    Wollongong NSW
    Need some insight on brakes on Mk6 R whether to go with DBA or offerings from FCP euro along with pads to suit.Not doing track but just street looking at Solid rotors all around .Also want some input on replacing all bushes . Any and all advice will be taken on board.Thanks to all
    Golf Mk6 R
  6. #6506
    Need some insight on brakes on Mk6 R whether to go with DBA or offerings from FCP euro along with pads to suit. Not doing track but just street looking at Solid rotors all around. Also want some input on replacing all bushes. Any and all advice will be taken on board.
    There is absolutely no need to look at importing a basic brake disk replacement from overseas when you can readily buy plenty of options locally. And with how heavy brake disks and pads are, you will pay a fortune in freight costs to bring in from overseas.
    Have a look on Run Auto Parts who are a European parts specialist supplier. They have Pagid and Bosch brake disks for the Mk6 R. Nothing wrong at all with DBA of course and there are plenty using them, but there are other options. The Mk6 R uses 345mm vented disks on the front and 310mm vented disks on the rear.
    The Bosch's are on sale which makes them quite attractive from a price point.
    If you want DBA, then somewhere like Brakes Direct would be a good place to buy them from.
    Fronts:
    Front Brake Discs 345mm Hella Pagid 8DD 355 109-541_2pcs for Audi VW Skoda
    Bosch Front Brake Discs 345mm BD1071 | Run Auto Parts
    DBA2808 DBA Street Series Standard Brake Rotor (note you need to order 2)
    Rears:
    Rear Brake Discs 310mm 54407PRO Hella Pagid 8DD 355 112-121_2pcs for VW Skoda Audi
    Bosch Rear Brake Disc Rotors 310mm BD1166 | Run Auto Parts
    https://brakesdirect.com.au/aus/dba2...ake-rotor.html (note you need to order 2)
    As for brake pads, if you just want a replacement pad then have a look at the options on Run Auto Parts or Brakes Direct. I would recommend a ceramic pad for normal street driving as they are a much cleaner pad (much less dust on your wheels) but good quality ceramic pads like Akebono Ceramic / ATE Ceramic / Brembo Ceramic are more expensive than normal replacement pads.
    Front pads:
    https://brakesdirect.com.au/aus/p851...rake-pads.html
    https://hp.net.au/home/product/ate-f...ke-pads-mk6-r/
    Rear pads:
    https://brakesdirect.com.au/aus/p850...rake-pads.html
    https://hp.net.au/home/product/ate-r...ke-pads-mk6-r/
    As for bushes, I would replace with factory bushes or in some cases, you can use bushes from the Audi TTS which has more solid bushes. Another option if you want aftermarket is Superpro or Whiteline who make polyurethane replacement bushes and control arms etc for the Golf.
    Here is a link to my old car, a Mk6 GTI. I replaced the lower control arm bushes with the Audi TTS ones. You can see the difference and also the part number if you want to buy them yourself: My other German fling: Mk6 GTI
  7. #6507
    Jun 2021
    Wollongong NSW
    Thankyou Lucas for your informative information
    Do you have links for the Audi TTS bushes
    cheers
    Golf Mk6 R
  8. #6508
    If you Google the part number and brand 33971 Febi you will find places in the UK selling them (which is where I got mine from). I found one place locally selling them on ebay Febi Bilstein Genuine New Replacement Wishbone Bush 33973 4027816339731 | eBay
  9. #6509
    Feb 2015
    Sydney, Australia.
    dba rotors and dba xp series (light track) are very good.
    can get on ebay and automotive superstore for cheaper usually than brakesdirect.
  10. #6510
    Dec 2018
    S.A.
    COOLANT LEVEL
    I just noticed my Cold level is about 3mm below "low".
    My Hot level is a little lower at 5mm.
    MY handbook states that the hot level may be above the Max i.e. meaning it rises. Is the book wrong?
    The gauge says the temperature is normal.
    cars (chronological) Morris850, Morris Mini DeLuxe, Cooper S, Mazda 1500SS, hard times so some old Holden, old Falcon Ute, better times so second hand Lotus Elan +2 (6 weeks, hopelessly unreliable) Chrysler Valiant Charger 770, second hand Datsun 260Z + 2 auto, Mitsubishi Cordia Turbo, Nissan 200SX turbo auto for 20 years(wonderful car burning ZERO oil after 200,000km & no problems when sold.. should have kept it), Toyota GTS 86 auto, now Golf R Mk 7.5 DSG built Aug2018, white.
