spray the contacts of the plug that goes into the power steering with contact cleaner and ensure they are shiny/good contact.
Clean the battery +ve & -ve terminals & also where they connect to the body/fuse block.
Check any fuses & relays associated with the power steering. If the fuses are cheap enough, replace them.
It sounds like there's a resistance somewhere. Generally, resistance increases as the joint heats up.
