Page 635 of 651 FirstFirst ... 135535585625633634635636637645 ... LastLast
Results 6,341 to 6,350 of 6510
Thread: Golf R Observations and Questions
  1. #6341
    Sep 2010
    Power steering intermittent fault
    Quote Originally Posted by gazzmo View Post
    Yes the steering is electrically assisted so when the battery starts to go you end up with any number of weird problems, at 4 years there is a strong possiblity it is the battery especially as you say at idle and low rpm.
    But it only happens after driving when the battery should be charged. On the other hand, I've had no problems when starting it from cold after leaving it unused for days i.e. when I'd expect a battery problem to show up.
    2010 Golf R Black DSG 5Dr MDI Fiscon Plus
  2. #6342
    Erskineville, NSW
    spray the contacts of the plug that goes into the power steering with contact cleaner and ensure they are shiny/good contact.
    Clean the battery +ve & -ve terminals & also where they connect to the body/fuse block.
    Check any fuses & relays associated with the power steering. If the fuses are cheap enough, replace them.
    It sounds like there's a resistance somewhere. Generally, resistance increases as the joint heats up.
  3. #6343
    Sep 2010
    Thanks - that makes more sense (at least to me). It only happens when parking after driving but not when idling e.g. at traffic lights. Could using Reverse gear somehow precipitate this issue?
    I've searched the web for info on the identification of which fuses relate to the power steering without success. I also wasn't able to identify the plug that connects to the power steering after a brief inspection. Is this information available on the web?
  4. #6344
    Apr 2010
    Well if that info isn't in your manual the next place to check would probably be https://erwin.volkswagen.de/erwin/
  5. #6345
    So I've had my Golf R for close to a year now.
    I am still loving the power on it and I never get tired revving it and hearing the pops.
    I bought mine second hand and the previous owner had his 18" painted gloss black. For some reason i'm still not feeling it against the RB colour.
    Thinking of changing them wheels to the new 18" Rotary that got released with the MK7's as part of the accessories range:
    2013 Volkswagen Golf 18 inch Alloy Wheel - Rotary #5G0-071-498-16Z
    Would coincide with a need to get new rubbers for my car.
  6. #6346
    Quote Originally Posted by amberzombie View Post
    You could just wrap the car in the performance shade i.e white and then the rims would look fine
  7. #6347
    Quote Originally Posted by parso_rex View Post
    Haha that is true... but a wrap would probably end up more than a new set of wheels?
    which reminds me... I might have to give you a call some time about a tune. I live down in Sans Souci and I've been researching on tunes for my R and I heard you're the man!
  8. #6348
    Don't believe everything you read on the internet
  9. #6349
    Apr 2011
    Brisbane, Queensland
    LOL, I know a guy
    ║ "The mind is willing but the body is weak" ║ Frazza's MY11 RB Golf R Instagram
  10. #6350
    Nov 2009
    Hills District, Sydney, NSW
    Especially that White is a performance colour
