Page 86 of 651 FirstFirst ... 3676848586878896136186586 ... LastLast
Results 851 to 860 of 6510
Thread: Golf R Observations and Questions
  1. #851
    Feb 2009
    All of the intercoolers differ a bit, I remember Guy saying there was some cost cutting on the R so isn't exactly the same as S3.. People doing big mods would most likely replace it anyway.
  2. #852
    Feb 2009
    Sydney, Australia
    Hey triode12, I've heard as well that the Pirelli's IC was larger than the GTI too.
    But it is 100% true about the Golf GTI and R having the same intercooler. Here are some pictures. I hope Guy_H has no issue with me borrowing his photos!
    This is from the "build photos" of Guy's Stage III S3 a few years back:
    You can see the APR Intercooler on the left, the S3's in the middle, and the GTI's on the right.
    And this is from the build photos of Guy's Stage III R.
    You can see the APR Intercooler next to the R's intercooler. You can clearly see that the R's thickness and end caps are identical to the GTI.
  3. #853
    Nov 2009
    Quote Originally Posted by Corey_R View Post
    You can see the APR Intercooler on the right, the S3's in the middle, and the GTI's on the right.
    APR on the left you mean? And to me, that S3 item looks a "touch" wider than the GTI on the left? Might be the angle of the photo?
  4. #854
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by dave- View Post
    *doh*
    Thanks, fixed that up.
    Yep - the S3 intercooler is definitely wider than the Golf R/GTI intercooler.
    This is why some people used to upgrade their GTI's to the S3 intercooler as a cheap alternative to the aftermarket products.
    But back to the original point of all this. Whilst I've heard good things about the Forge twin-cooler, since the Golf R's IC is not the same or as capable as the S3 IC, to me it makes more sense to address that deficiency first before adding 2nd intercoolers.
  5. #855
    Oct 2010
    Southport, Queensland
    Ok I will get a blue one. It is a great colour and different from all those white ones being ordered.
    Bockey
    2023 Tiguan R Driver
  6. #856
    May 2009
    By the looks of things, the R/ MK6 GTI may now have the Pirelli IC as well (confirmation is needed on this). The difference in thickness between the Pirelli and S3 IC is 1cm. And conclusions made was that the increase in performance was neglible and that it was money better spent on the APR IC instead. So as a cheap alternative to upgrading to the APR IC (with all the cost and trouble involved in removing the original), the Forge twincooler was recommended. Hence, why I mentioned it over the upgrade to the S3 IC.
    *doh*
  7. #857
    Apr 2010
    New to Brisbane
    So has anyone removed the ugly front number plate holder from their R yet? If so, how far apart are the screw holes? After a recent decision to move states I will now be forced to have non European plates that won't fill the holder and am thinking about removing it again. Would prefer to do this at delivery if possible before the application of paint protection film.
    United Grey R: All the accessories (leather, not Recaro's though), S2P paddles, Kuftech DVD in motion. Carbon grill, mirrors and diffuser awaiting to be fitted.
  8. #858
    Oct 2010
    Probably only 3 options:
    1: sell it and buy a Prius (and don't replace it with a GT3 - that's for sure!)
    2: park it away from the house
    3: sound proof your garage / daughters room
    tough one, I'm sure there will be plenty of forum members that will surely help you dispose of it!
    Perhaps she could move!!
    Bockey
  9. #859
    Feb 2009
    Quote Originally Posted by xrayshaggy View Post
    If anyone has taken their number plate holder and doesn't want it I'll grab it/buy it.
    Cheers,
  10. #860
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by G-rig View Post
    Cheers,
    Yep, plenty of people have removed their number plate holder. On the GTI, a trick was to just use the screw hole plugs to plug up the holes left by the plate holder and not covered by the number plate. But the GTI and R's plate holder is different and with the R you would have 4 holes visible. So I think that this it he more elegant solution!
    AdamD's Lakin Plate Holder Install
    Of course, AdamD's car is a GTI too, but Lakin Plates can make the same bracket but for the R (it probably has 4 screws, but they're black anyway).
    For reference of what the R's plate holder looks like, check out the Blue R in my post, immediately below AdamD's
