Page 85 of 651 FirstFirst ... 3575838485868795135185585 ... LastLast
Results 841 to 850 of 6510
Thread: Golf R Observations and Questions
  1. #841
    May 2009
    Quote Originally Posted by sandandsalt View Post
    Thank You.
    Great forum!
    Stage two will do.Yes would like to do some track days. 6 a year,
    Tune i $1695, Air $575, Fuel pump not needed as yet, inter cooler $2000, Exhaust varies in prices full $4000 and yes must first listen for drone, half Not priced, down pipe $2500 plus labour for install.
    This is an inexpensive tune.
    r36 / r soon.
    There are other brands of downpipes and exhaust systems besides APR which work out a lot cheaper than that. Cogdoc just did a group buy for 42DD and the DP alone came to around $800 landed.
    I would research more on the intercooler. The one in the R is only not that much different to the S3 intercooler (difference is plastic ends caps). Perhaps add a forge twincooler to the existing IC would have more gains than replacing the intercooler itself.
  2. #842
    May 2010
    Quote Originally Posted by triode12 View Post
    Hey,
    So Is that right about the cooler? Is the only difference the ends of it? So the actual core is the same? That's surprising, cause vie heard a lot of dominating S3 vs R cooler talk.
    Which does make sense mind you at face value cause the car costs more, but anyway there you go.
    Hey what are these downpipes? $800 is more my alley, any link or pic of them? Is 42DD tbd brand?
    Thanks!
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  3. #843
    Feb 2009
    Sydney, Australia
    No, that's not correct. The S3's intercooler is about 50% thicker than the R's - so it's more than just the end cap difference. I've still got the pictures from the S3 Stage III conversions where they've got the Stage III Intercooler, next to the S3 intercooler, next to the GTI intercooler. The R uses the GTI's intercooler.
    As for 42DD. They make a "modular exhaust package". This is their link for the downpipe. It's a much cheaper product than competitors such as Milltek and APR, and well, it should be. It's not even a Mild Steel exhaust, let alone a Stainless Steel exhaust. It's an aluminized steel exhaust!
  4. #844
    Sep 2010
    I'm planning to replace the stock DSG paddles. Step one is to disconnect the fuse for the steering wheel airbag before removing the steering wheel cover.
    Unfortunately, the manual does not specify the fuse locations. Can anyone provide a diagram of the fuses and their functions?
    Thanks
    Lex
    2010 Golf R Black DSG 5Dr MDI Fiscon Plus
  5. #845
    Feb 2009
    Sydney, Australia
    I think most people just disconnected one of the battery terminals and left it at that...
  6. #846
    Sep 2010
    Quote Originally Posted by Corey_R View Post
    Yes but that produces error codes that others have said will hopefully resolve after driving but might require resetting by the dealer.
    Identification of the fuses should be possible and would be a simpler solution.
  7. #847
    Feb 2009
    Sydney, Australia
    Sorry. I presumed that you want to pop the fuses because that's what the instructions say. The instructions also say to disconnect the battery too...
    Of course, one for multiple reasons and makes the other redundant
  8. #848
    Quote Originally Posted by Lex200 View Post
    I rang my local VW service centre (Artarmon) when I did my paddles to get their advice. They didn't have a fuse diagram 'at hand' for the R, and told me to just disconnect the battery. They did warn it might throw up error codes that would require clearing by them.
    In the end I had to disconnect the battery twice (the horn didn't work after my first attempt at putting it all back together, but I didn't realise for some time), on both occasions I got the ESC warning light which cleared after I drove a few metres. Disconnecting the battery is no different to just changing a flat battery, and I'd be pretty dissapointed if I had to pay a dealer to reset some codes everytime I did that!
    2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
    2015 MY16 Golf GTI - 5 Door, DSG, Carbon Grey, Leather, Sunroof, DAP.
  9. #849
    Yep, same as HPSOV, just disconnect it and leave it 15. Provided you put it all back together the way you took it apart, you'll get error warnings that disappear straight away.
  10. #850
    May 2009
    If what you say is true about the R's intercooler i.e. that it identical to the GTI's stock intercooler, then the Pirelli's intercooler is different yet again. Admittedly, my research was done almost a year ago, but I distinctly remember that the Pirelli's intercooler was different (larger) to that of the GTI - i.e. the roughly the same dimensions as the S3 intercooler only with plastic end caps. And the comparisons people were making between them concluded that it was not worth the effort upgrading the Pirelli's IC to the S3 IC because the gains (if any) were minimal - the APR intercooler was recommended instead or the Forge twin cooler addon.
    I am assuming of course, that the Pirelli engine is the same as the R. I would think it silly for VW to uprate the engine to 195kw (Pirelli is 169kw)and stick an IC that is smaller than that of the Pirelli's.
