Certainly not on the Australian models - that's for sure!
Printable View
It may seem a strange request but are there any simple mods to reduce the noise of the Golf R.
My daughter is very unhappy that I wake her each morning when I leave for work and that her whole room vibrates whenever I reverse into the drive.
Probably only 3 options:
1: sell it and buy a Prius (and don't replace it with a GT3 - that's for sure!)
2: park it away from the house
3: sound proof your garage / daughters room
tough one, I'm sure there will be plenty of forum members that will surely help you dispose of it!
There's a process where a 2 part expanding foam is used to spray under floorboards to give heat and sound insulation.
I could give you some names of companies in western sydney, but can't really help with VIC.
Might be worth ringing some roof insulation companies?
Otherwise you could try Urethane wholesalers, as they will supply the chemicals and equipment to the contractors.
get daughter to leave home ?
http://www.vwwatercooled.org.au/imag...tor/smilie.png
