Page 583 of 651 FirstFirst ... 83483533573581582583584585593633 ... LastLast
Results 5,821 to 5,830 of 6510
Thread: Golf R Observations and Questions
  1. #5821
    Apr 2010
    No worries. Don't forget to read the manual while you've got it out
  2. #5822
    sydney
    Lol thought I did but I missed that part
  3. #5823
    Mar 2008
    Sunshine Coast
    May have already been posted but Volkswagen Driver Jan 2013 issue has a special on the Golf R
    Nothing major but some good reading
    https://itunes.apple.com/au/app/volk...468631656?mt=8
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  4. #5824
    Mar 2008
    Sunshine Coast
    Oh and those screenshots I posted are from the VW Golf R app (I got it a while back).
    Don't bother getting it - pretty light on content.
    Edit - oooops, think the screenshots were on the other forum
  5. #5825
    In the MFD I can't work out how to display the boost in PSI
  6. #5826
    Apr 2010
    It's in the options, the one under Parameters iirc, where you can change all the units.
  7. #5827
    Yeah found it. This is going to cause some grief when flashing cars unless the device is disabled as it ties up the OBDII port. Lots of fun though.
    I've learnt that its hard to take pictures of boost reading 28 psi especially at night
  8. #5828
    Apr 2010
    Yes there's an option to turn it off, then to turn it back on you have to hold the OK button for 30 seconds.
  9. #5829
    Yeah done all that but during the flashing process which is normally about 18 mins you don't want things to be interrupted at all and I need to make sure that its not just sitting there polling things while its turned off. The fact that it can be turned back on with the 30 second depress means to me that it it monitoring things in some way.
    Its a good piece of gear though
  10. #5830
    Apr 2010
    No worries, just keep the FIS box in the little compartment under the light switch and then it's pretty easy to disconnect/bypass when needed. It's recommended to disconnect the relevant fuse (or battery) when doing it.
