Page 574 of 651 FirstFirst ... 74474524564572573574575576584624 ... LastLast
Results 5,731 to 5,740 of 6510
Thread: Golf R Observations and Questions
  1. #5731
    Feb 2008
    ACT
    Quote Originally Posted by Allegiance View Post
    Or just press the parking sensor button and they turn on whenever you want
    There's a parking sensor button??
    Will have to look for that tomorrow - thanks
    Edit: Still, in every other car I've got with parking sensors they are enabled automatically when driving at slow speeds, so I stand by my stupidity for not realising I had to manually engage the sensors when I want to use them.
  2. #5732
    Feb 2010
    Quote Originally Posted by jamesatfish View Post
    The little P button in this photo just to the right of the shift lever.
    2020 VW Golf R
  3. #5733
    Jul 2012
    Gold Coast, Qld
    Yes, I was going to say that. Speed has to be under a certain value but yes, just press the button jamesatfish.
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  4. #5734
    Jul 2012
    Gold Coast, Qld
    In other news, just installed Volkswagen Racing's "Quickshift Gearchange" in the shortest throw position and I have one word to describe it: AWESOME.
  5. #5735
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by parso_rex View Post
    The more boost you run the more pronounced the blow-by will be and certainly the piston to bore clearances will differ amongst all the cars which is why you will see some owners complaining about excessive oil consumption. So maybe your just lucky.
    My own car is actually not too bad but some customers cars sheezus !!! or maybe its simply because you've never experienced the awesomeness of a proper re-calibration with a real man level of tune on it.
    Just sayin'
    The former I'd say as mine has never used oil. My GTI used a bit but not excessive
    My commute allows me to use boost a fair amount and I tend to drive it in the 3,000-4,000 band a lot on the way to work but D mode home.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  6. #5736
    Quote Originally Posted by Machine View Post
    Good to hear a local review. I have been contemplating getting either the VWR or HPA short shift kit for my car. I used to have the DieselGeek short shfter but didnt like it. Currently ive got the 42DD solid shifter bushings which made a nice difference to the feel of the gear changes, although they do not shorten the throw.
    The 42DD bushings remove the rubbery feel that the shifter has, so they might be a good (and cheap at $50) option for you to add to the VWR shifter.
  7. #5737
    Feb 2010
    I had the 42DD bushings on my Polo, it really did tighten things up.
    2020 VW Golf R
  8. #5738
    Jul 2012
    Gold Coast, Qld
    I'll definitely consider that. Have you got pics of the bushings Lucas? Can you snap one of the shifter mechanism on your car?
  9. #5739
    Not a pic of the whole shifter mechanism, but i took a couple of random shots with the mobile phone when installing the 42DD bushings.
    URL=http://imageshack.us/photo/my-images/809/42ddshifterbushings.jpg/][/URL]
  10. #5740
    Jul 2012
    Gold Coast, Qld
    OK, so did you install 2? One in each location (i.e. upper right and lower left rods?)
