Page 562 of 651 FirstFirst ... 62462512552560561562563564572612 ... LastLast
Results 5,611 to 5,620 of 6510
Thread: Golf R Observations and Questions
  1. #5611
    Jul 2012
    Gold Coast, Qld
    ^ Could be. They've been on cars in Canada for ages.
    Click or tap --> MY13 CW Golf R | Manual | ACC (deleted) | 19" Black Talladegas (sold) | Satnav-Dynaudio
    APR Stage 2+ w/RFD | Autotech HPFP | IE CAI + BSH Heat Shield | NPC Clutch + SMF | HPX 3" TBE | CTS FMIC | VWR Short Shifter | Comp Haldex | Uprated Engine Mounts | MCA Red Suspension | HP Superpro LCA/ALK/Ball Joints | Superpro Rear Bushes | AP Racing BBK | P3 Gauge | 16% tint
    Track wheels: 18x8 ET45 Enkei Racing PF01 | Tyres: 245/40R18 Yokohama Advan A050 Soft | Street: 245/35R19 Michelin Pilot Sport 4 S
  2. #5612
    Feb 2010
    I don't have the option, MY13
    2020 VW Golf R
  3. #5613
    Apr 2012
    Thanks for the replies everyone. Might see if I can find the fuse for the DRLs and pull it out. I drive with the lights on all the time so don't really need/want the DRLs turning on as well. I know they give the R a unique point of difference against all other Golfs but DRLs are popping up on everyhting now - the current Merc C Class and even the Kia Optima have DRLs in a similar position to the R.
    Quote Originally Posted by Machine View Post
    Congrats on the new car, by the way. Was it a factory order?
    Thanks mate It was a dealer car that they ordered for their own stock. Tried to get a factory order but was told it couldn't be done. I put down the deposit in August, the car was built in early September, and it arrived in Oz late October.
    A couple of observations:
    - If you turn the headlight switch to '"parkers" position and get out of the car and lock with the key fob, the inside section of the LED tail lights turn off. If you unlock the car the inside section turns on again. I also read on here somewhere that the same thing happens when you open and close the driver's door, but I can't get that to work on my car.
    - The sound of the air being pumped through the cooling/heating dash vents is very noticeable and 'whooshy' even at the lowest fan speed, much more so than previous cars I've owned. It gets even louder with the AC on. Anyone else notice this?
    - When I slowly push the clutch in slightly (a few centimetres) and hold it there is a small pulsating feeling coming through the clutch pedal. It is more noticable with the AC on. When I push the clutch pedal further in the shudder goes away. Any ideas? Problem or normal?
  4. #5614
    Jul 2012
    Gold Coast, Qld
    Quote Originally Posted by nickows View Post
    ... but DRLs are popping up on everything now
    Yes, we see the LED's everywhere now ever since Audi started it, but you know what? You drive an R. Be proud.
    Nope, haven't noticed. I keep the AC on all the time, pretty much on AUTO and it doesn't bother me. Keeps me cool as a cucumber. Check that all your vents are open, including the one in the back (and close the one in your glove box unless you're chilling the champagne).
    Normal. All clutch pedals do this. Don't ride the clutch!
  5. #5615
    Feb 2008
    ACT
    I've certainly noticed on mine that the low fan setting is still quite 'blowy', certainly more than other cars. This is with all vents opened back and front - the low setting still seems quite forceful.
  6. #5616
    Apr 2012
    Thanks, will check other vents
    My two previous manual cars didn't have the shudder I've described. And I don't ride the clutch - it's something I noticed when I first picked up the car.
  7. #5617
    MY13. I don't have that. Interesting, indeed...
    https://docs.google.com/open?id=0B9K...HY0Zmp5OUx3MDQ
    MY12
    MY12 Golf R | 5 Dr | Candy White | DSG | 19"Black Talladegas | ACC | RNS510 SATNAV | Sunroof | RVC | BT | MDI
    Ordered - 28/02/12 | Collected - 14/03/12
  8. #5618
    Jul 2012
    Gold Coast, Qld
    ^ Nice. That settles that.
  9. #5619
    Jul 2012
    Gold Coast, Qld
    I was only kidding about riding the clutch. But seriously, don't. What you're feeling under your left foot is the flywheel spinning. Completely normal, trust me.
  10. #5620
    Nov 2010
    Burpengary, Queensland
    I'm a little embarrassed to admit that even after more than 6 months ownership, I only just found that this button has 2 functions.
