Good on ya
Nothing like a bit of red flashing numbers in the cockpit![]()
8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
Indeed it does
Especially on full boost
Just follow install instructions exactly and don't rush the vent removal
Ran a foam strip to seal around the air inlet - has reduced intake noise
Why do they have the intake open to the engine bay ???
I understand why it isn't a ramjet type intake and why it picks up dual intakes but it could be better designed.
My only thought on that intake design is to allow cooler air to flow into the engine bay to keep things a smidg cooler for the engine, gearbox & firewall perhaps, rather than as a secondary place for the inlet to pull air from?
Huh ????
The actual air intake is pulling air (-ve pressure)
Do you mean through the grill ?
Confused
Notice there is a splitter in the grill intake piece, with one section going to the intake, and one going to the gaping hole underneath..
