Page 475 of 651 FirstFirst ... 375425465473474475476477485525575 ... LastLast
Results 4,741 to 4,750 of 6510
Thread: Golf R Observations and Questions
  1. #4741
    Mar 2008
    Sunshine Coast
    Replies to SF are all auto responses - canned replies.
    The theme is always the same
  2. #4742
    Nov 2009
    Hills District, Sydney, NSW
    Quote Originally Posted by brimway View Post
    shame, it took you 4 minutes to bite not good enough. Iwa sh*t at maths, 5 minutes
    gold
  3. #4743
    Quote Originally Posted by Candyman View Post
    I'll be staying away from them thanks
    Very very average.
    Up to you mate.
    I dislike them with a vengeance
    Squeelers, fade, chattering, uneven surfacing on my first two sets.
    Yes, they dust less but that is about it.
    YMMV
    Well perhaps you were unlucky and got a bad set or something. No squeaking or any noises whatsoever, no fading, no chattering and they brake well from the first application. Mine are absolutely perfect, and i have 2 other friends running the Remsa pads now (MK5 GTI and a Mk6 R) and both friends are very happy with them as well.
    If not Remsa, then get Bendix, ProjectMu, etc etc...whatever...something else to reduce the dust.
    It might also be beneficial to understand if you are referring to the "correct" Remsa, as there is an American Remsa company, and then there is also a Spanish Remsa. Im talking about the Spanish one.
    American one: http://www.remsaofamerica.com/
    Spanish one: http://www.remsa.com/
    Furthermore, the guys from GSL Rallysport said that they use the Remsa pads in a large range of European cars, even Lamborghini's / Porsches etc. Im sure if they were not a good quality pad, then they would not be used in these high end vehicles.
  4. #4744
    Lake Macquarie
    ^ just get Remsa brake pads guys......less than $250 for the complete set. You have probably spent more than that on wheel cleaners already....
    Brake dust is reduced significantly - about 70-80% less.
    Up to you mate.
    YMMV
    American one: Disc brake pads for Domestic and Import Vehicles - Remsa of America
    Spanish one: Remsa
    I use them as well and mine do not squeel or fade or chatter but they do reduce the brake dust significantly. When I need new pads I will be getting the same ones.
    Golf R 5 Door DSG, Rising Blue, 19" Wheels (Silver), Leather, MDI, RVC, Bluetooth, RNS510, APR Stage 2, APR Divorced DP, APR HPFP, VW Racing CAI, S2T Paddle Shifters, Sprint Booster
  5. #4745
    Mar 2008
    Sunshine Coast
    The issues with them are well known
    Higher metal content and much harder causing less dust, more noise and moving the wear from pad to rotor
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  6. #4746
    Nov 2010
    Burpengary, Queensland
    That's what makes me hesitant to buy them. I would much rather the dust come from the pad surface than the rotor and the OE dust, being black, would indicate that is is from the pad. Simple physics?
  7. #4747
    Quote Originally Posted by Klink1313 View Post
    Exactly.
    Your a hard egg to crack. If you could point me to where this info is "well known" id like to read it. The way i see it, is the stock disks normally don't last more than 60-80,000km anyway (which is a pretty poor life span). My mate has been running the Remsa pads on his Mk5 GTI now for approx 25-30,000km and i looked at his disks yesterday (when i was servicing his car) and his disks look perfect still.
    Each to their own obviously, but for me, the abundance of pad dust was something i couldn't stand. Plenty of other people on here are running the Remsa pads (im talking Polo GTI's / MK5 GTI's etc) and the only "negative" comment ive ever heard about them was from Candyman.
  8. #4748
    Nov 2010
    Saying rotors look perfect is not really a reliable way to determine their condition. I think measuring them would be a more accurate method. If you did measure them, what did you find?
  9. #4749
    No measurements - just a thorough physical inspection. There is no lip on the disks (to indicate alot of wear) and the disks are nice and smooth (no scoring) and the disks are still quite dull which is what you want (not glazed).
    The disks on this particular car were changed at the 45,000km service (as per the service records). The original owner of this car lived in Sydney so i assume alot of stop/start traffic.
    The pads appear to have about 0.9cm - 1cm of pad material still left on them, which after 25-30,000km of mostly city driving in a DSG car is pretty good.
  10. #4750
    Oct 2010
    Got sick of the dust also. Easy fix is get yourself a $200 kartcher (hi pressure cleaner). Takes less than 1 minute every two/thee days and wheels are a gleamin'
