Page 408 of 651 FirstFirst ... 308358398406407408409410418458508 ... LastLast
Results 4,071 to 4,080 of 6510
Thread: Golf R Observations and Questions
  1. #4071
    Dec 2010
    How hard is it to knock the wheel alignment out on a Golf R? Does the AWD system make the wheel alignment a bit more sturdy? The reason I ask is - on Monday I smashed this pot hole and it gave the car a good jolt. In fact, I originally thought I had busted a rim I hit it that hard.
    After visually inspecting (only the outside) of the rim, there's no damage at all to see (or touch), the car still drives straight, and there's no wobbles or vibrations felt. But I just can't help but feel something isn't right. I don't know if I'm imagining it or not.
    Also, I'm not too sure if maybe the servotronic steering system is now compensating for something. If I hold the steering wheel dead straight, the car tracks left. If the steering wheel is like... 5 degrees off center (turned right) the car tracks straight. I can't remember if that's how it was before, or if my steering/wheel alignment is out.
    Then again - if the camber of the road changes - I can hold the steering wheel dead straight, and the car tracks dead straight.
    Am I paranoid or not?
    But back to my original question - is it "easy" to knock out the alignment? I was doing about 50km/hr when I hit this thing. Maybe the sound it made of it jolting the whole car made it sound word than it actually was.
    My car: MY18 Arteon
    My car #2: MY22 Volvo XC40 Pure Electric
    Her car: MY22 Skoda Octavia Limited Edition Wagon
  2. #4072
    Erskineville, NSW
    Quote Originally Posted by sillywet View Post
    Regarding the maximum 4000 revs with clutch in comment, I actually haven't tried revving it that hard with the clutch in yet. Will try it tonight and see if mine does that too. Doesn't sound right to me...
    Another question for those of you with manual - have you noticed when you drive off really sedately in first gear, below about 2000 revs it sort of feels like it hesitates? Sort of hard to describe. Only happens initially and only if you're at like 10-20% throttle. If you have a better crack at the accelerator it doesn't happen. Can't tell whether it's a fly by wire thing or more to do with the 4WD system sorting its thing out at low speeds. Anyone know vaguely what i'm experiencing and got a reason?
    The 4000rpm thing is built into the software to stop you abusing your car.
    The hesitation thing - my Skoda did it too. If you look at the torque curve, it goes up, goes flat at about 2000rpm & goes down about 4500rpm(?) - Like a mesa. I think under part throttle it starts to dump boost or similar to flatten the torque curve.
    My low rev hesitation went away after I got remapped. The torque curve then looked like Mt. Fuji, therefore the torque wasn't being artificially limited.
  3. #4073
    Jul 2011
    Burwood, VIC
    Quote Originally Posted by stephen8512 View Post
    Hey all
    WHenever I start the car and drive normally and get the car to warm up, during initial take off, the engine has developed an almost diesel-like noise? Its not as pronounced as the diesel engine sound you hear in most oilers, but from in the cabin, it sounds like that in 1st and 2nd....sounds almost like one of those small trucks when they go from first to second...that diesel noise....of course not as LOUD but from in cabin i can hear it.... I dont remember it doing that at all when I first took delivery of it??
    But the thing is, after driving it and the car is warm, the noise goes away? any idea what it can be? its done just shy of 10K kms...and no engine mods on the car except a GIAC flash stage 1 and a sprintbooster
    At idle it sounds normal....but only when its a cold start, and when u drive it from first and second.....getting up from 0km to say, 50kms....in normal D mode...and letting the gears change when it wants to which is usually about 2K rpm for me
    Depending on how hard I press the accelerator, the noise is there. But since its a cold start im not booting the car or anything..just driving normally till it warms up. WHen its warm and when I take off from, say, a set of lights normally, it doesnt make any sound?
    Any idea what it could be?
    Oh and also, does the Golf R come with the REV D piston DV? or does it still use the diaphragm?
    Its the FSI fuel injectors that you can hear tapping / rattling away. It is especially audible at idle and moreso with a cold engine as the engine is idling higher for the first minute or two (auto choke).
    Totally normal. All the "newer age" direct inection engines do it from one extent to another.
    Quote Originally Posted by dave_r View Post
    I liken the sound of the engine to my old 4L SOHC falcon with noisy tappets. It is definitely not the quietest smooth sounding engine. A mate commented on mine when we did the oil change last week saying his Mk5 GTI was quiet, that was until we did his car and it sounded the same lol.
    And yeah its a piston DV.
    I just noticed what I think is this same rattle after having an oil-change service at volkspower at 4000kms. It can be heard only upon acceleration, but occurs all the time, not just when cold. The rattle is only light, but because I've been used to a beautiful silky smooth engine noise since new, it's starting to annoy the cr@p out of me
    Is it just something that you have to get used to ?????
    - 2006 Audi B7 RS4 sedan, black, APR supercharged
    - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
  4. #4074
    Oct 2010
    Southport, Queensland
    Quote Originally Posted by bluefrog View Post
    A VW Tech told me that the arm on the waste gate rattles when the engine is cold. VW can fix it with w spring clip apparently. My "diesel-like sound" disappears after a warm up.
    Bockey
    2023 Tiguan R Driver
  5. #4075
    Feb 2009
    Sydney, Australia
    The wastegate rattle and the clip solution is for the K03 based EA888 engines. Never heard anyone mention the K04's rattling before...
  6. #4076
    Yes mine does this occasionally. Only on light throttle input at low rpm (eg pulling away from a standstill at an intersection) every now and then.
  7. #4077
    Apr 2011
    Cheers Brad, that makes sense. Just another reason for me to man up and get a tune.
    Also tried that free reving thing last night. That absolutely blows my mind! What revs does the launch control sit at in the DSG? Surely that's above 4000? Do the guys with manuals who hit the drags have this over-ridden or is 4k a reasonable spot to dump it anyway? Not that drags excite me at all but i would have thought with some sticky rubber and 4WD you'd bog it down a bit if you dropped it from only 4k?
    2011 R Manual 3dr Rising Blue
  8. #4078
    Aug 2007
    Does anyone find the headrest too far forward? I've only had my R for 24 hours but I thought I'd be able to find a comfortable seating position by now.
    I have to recline the seat quite a lot for it to not be a constant niusance. I know it's a safety feature, but it shouldn't come at the expense of being able to drive comfortably without constant distraction!
    Some solutions I've found are:
    1) Flip the front headrests around, i.e. back to front
    2) Move the rear headrests to the front
    3) Fit headrests from 2006-2007 model Golfs, as these were either tilt-adjustable or protruded less
    4) Recline heaps
    Just wondering if anyone else notices the same thing? I found it to be a problem on both leather and cloth seats (test drove a leather demo, my car is cloth)
  9. #4079
    Jul 2011
    Burwood, VIC
    Quote Originally Posted by Corey_R View Post
    I've got no idea whether it's the turbo or the FSI fuel injectors like Lucas mentioned or what, but it's probably not so much of a rattle than a slight tinny sound, only when I accelerate, and (I think) only since the oil change.
  10. #4080
    Feb 2009
    Sydney, Australia
    The DSG limits the "launch control" to 3000rpm, although recently it seems that some peoples limiters seem to be "Missing" or something and they can launch at whatever they want to. Feel sorry for them clutches though
    Quote Originally Posted by chylld View Post
    Some people have complained about it in the past. Raise the height of the headrest as much as you can...
