A couple of questions then.
What is different between the GTi motor & the R donk? I see the compression is slightly more and heard something about a steel timing chain??? Is the bottom end the same?
Also has anyone been able to log the torque split with the haldex unit thru various situations? I read somewhere it can split up to 100% rear which is goodPity there is no manual overide to lock in what you want, but anyway...What ratio is straight line for instance at a constant 100km for example.
Also regarding oil changes has anyone bothered to do a 6 monthly change themselves?
Cheers Paul
