Page 383 of 651 FirstFirst ... 283333373381382383384385393433483 ... LastLast
Results 3,821 to 3,830 of 6510
Thread: Golf R Observations and Questions
  1. #3821
    May 2010
    Melbourne, Victoria
    Good to see others are getting similar figures to me. I generally get between 450-500km per tank with mainly city style stop start driving. Have not taken it out on the freeway too much for extended periods of time to see what I can get out of a tank. Initially I was concerned about this figure, but in the end my fuel consumption is no greater than my previous car which required PULP also, but the Golf R has so much more power and fun to drive it does not bother me. Conclusion - I have come to learn that I will never really believe the consumption figures given my car manufacturers.
  2. #3822
    Erskineville, NSW
    Quote Originally Posted by stephen8512 View Post
    but I digress...so what could potentially be another reason for fuel consumption being poor (as a general question I'm putting out there to pple, not specifically on the R)? .
    Maybe your engines aren't run-in yet?
    The Skoda was getting mid-7s in the first 5000km, then dropped to high 6s (like flicking a switch) & continued to improve right through to 25,000km when it levelled off.
    At a guess, are the people with the worst economy running (heavy) 19" rims? I know my economy took a hit when I went from 16s to 17s & gained 1kg per corner & took another hit when I fitted the Audi rims and gained another 1kg per corner.
    Plus all the usual other stuff like:
    *AirCon on 24/7
    *Boot full of crap
    *Low tyre pressures
    *roof racks
    *Ambient Temperature - Winter I use about 15% more fuel than summer.
    *Wet Weather - you'll get about a 1l/100 hit from wet roads
    *Traffic conditions - my usual commute i average 6.7L/100 but if I hit stop/start traffic it goes up to 10L/100
    *Not reading traffic conditions, blah, blah, blah
  3. #3823
    I have no idea how you guys achieve such low fuel consumption. Mine is sitting on 14.8L/100KM. I drive around Sydney most of the time. A full tank gives me around 360kms. I do have a bluefin installed not sure if that would affect it?
    Candy White Golf R DSG MDI Bluetooth & Bluefin installed!
  4. #3824
    Newcastle, NSW
    Quote Originally Posted by abufijli View Post
    Driving style (AC on, hard on and off accelerator, not reading traffic) and traffic.
    I don't drive to work so don't have the heavy traffic issue - I'm mostly on the open road so my fuel consumption is better.
    Audi S3. Sold
    Golf R. Sold
    Citroen DS3 Dsport. Sold
    2016 Skoda Octavia RS Wagon.
  5. #3825
    Quote Originally Posted by Ideo View Post
    AC on yes, traffic yes but I have tried driving very smoothly for a while and it never went below 14.6L/100km.
    Its a massive difference to everyone on here. I think its a bit strange.
  6. #3826
    Erskineville, NSW
    I'd be bringing it up with the dealer. Maybe you'll have to do a comparison consumption test with another vehicle. It would probably be a good thing if you had a record of actual consumption using mileage & fuel dockets.
  7. #3827
    Nov 2009
    I have 19" rims, AC on all the time, foot down (just cause i can) and still don't get below the 500km a tank mark unless i leave it in sport mode the whole time.
    Might be worth getting it checked out abufijli, assuming you are doing your own calcs and not just going from the MFD figures.
  8. #3828
    Quote Originally Posted by Glennb View Post
    The figures Im using are straight off the MFD. Are they not accurate and how do I do my own calc? What is an accurate way?
  9. #3829
    Mar 2008
    Sunshine Coast
    Fill the tank
    Record start km's
    Drive until next fillup and record km's driven and liters used
    You can then calculate L/100 km
    Do this 3-4 times
    Average results
    The MFD usage should be reset often, especially on a new vehicle - it is often inaccurate early on
    Are you seeing instant fuel use or average fuel use in the MFD ?
    They are different
    There is also daily and overall fuel use on MFD. Which are you looking at ?
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  10. #3830
    Quote Originally Posted by Candyman View Post
    Fill the tank
    Record start km's
    Do this 3-4 times
    Average results
    They are different
    Im looking at the overall fuel usage. My car has only done 3500km so far. Could it be still settling down?
    Do you guys think having a Bluefin installed will increase fuel consumption?
