Page 305 of 651 FirstFirst ... 205255295303304305306307315355405 ... LastLast
Results 3,041 to 3,050 of 6510
Thread: Golf R Observations and Questions
  1. #3041
    Nov 2009
    Hills District, Sydney, NSW
    Not if he wants to drive it home.. it is ony a flight away
  2. #3042
    Oct 2010
    Quote Originally Posted by Smasho87 View Post
    Hey guys
    I got a mrk 5 gti, I wanna get a golf r 5 dr dsg but I can't find any. Dose any one know if any dealers have any? {I don't want to wait 12 months }
    I've been to my local, mascot they have 4 3rd r"s no 5 doors
    Please help.
    Interesting. Has news of the scirocco killed 3dr sales? I can smell some bargains!
    I suspect you might need to get in line and wait (like we had to hehe)
  3. #3043
    In answer to a couple of questions now I'm back on:
    Quattro Motors were fine, all very low key though which is fine for a stage 1 (ECU flash only). Don't remember seeing a dyno facility? They didn't know about the $100 service re-flash but made a call to APR once I told them. I went with APR because Quattro Motors are a 15 minute walk from my place, no other reason.
    As far as the sound is concerned, I kept the original head unit and had the following installed:
    • Dynamat extreme front & rear doors
    • Focal 165KRXS woofers & tweeters in front (165KR2 were too tight)
    • Focal 165V30 woofers & tweeters in rear
    • Hertz ES200 sub in fibreglass enclosure (left rear storage area)
    • Alpine PDX F-6 multi channel amp
    • Alpine PDX M-6 mono amp (sub)
    I also requested a quote for Dynaudio from another dealer but it took so long to get the quote, I went ahead with the Focals.
    I went a bit over the top with the rears but I wanted to make sure I got as good as I could get without tuning etc. The install by Westside in Cannington is absolutely first class, they kept the car for 4 days, the installation of the Dynamat and the front speakers is tricky and time consuming (that is a nice way of saying that they had to do unspeakable things to my new car). I made a conscious decision not to go down to see what they were doing
    The only thing that you can notice from stock is the sub in the left rear and that is only if you are familiar with the car, otherwise you would not notice. I even have a sub level dial in the small closable storage compartment to the right of the steering wheel.
    The sound is fantastic, so clear and detailed. I went to my son's house, opened all the doors and played Back in Black at approx 65% volume, I can assure you the whole street heard it very clearly
    I'll try and get some photos of the sub and amp installs tomorrow.
  4. #3044
    Apr 2011
    Are you running the factory RNS/RCD510 or an aftermarket HU or processing unit? afaik the head unit has no pre-amp outs and the amps you've chosen don't accept high level inputs?
  5. #3045
    Feb 2009
    Sydney, Australia
    Sure they do... how else would the Dynaudio cars have their own 300/600w amps?
  6. #3046
    Erskineville, NSW
    Quote Originally Posted by Corey_R View Post
    High level inputs using amps designed to take same?
  7. #3047
    Apr 2011
    Unless you get a different unit when you order a car with dynaudio I'd just assume the Dynaudio amps take a high level input?
    All the pictures of the 510's from ebay don't appear to have pre-amp outputs.
  8. #3048
    Jan 2010
    Springwood
    i imagine that's what the -12db VCDS setting is.
    it may be a cross between pre-outs and high level, specifically for the dynaudio amp.
    it wouldn't bypass the output stage in the standard headunit though,
    so it's no different to using hi level output converters.
    Unless it has some other method of transporting the signal, like Canbus?
    2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
  9. #3049
    Quote Originally Posted by dny View Post
    Now you're assuming I know all the details
    I am using the original RCD-510, what black magic they used to put it all together - I have no idea! I asked for a quote that utilised the factory head unit and that's what I got.
  10. #3050
    Apr 2011
    Quote Originally Posted by police state View Post
    haha as long as its all together, it works and you're happy with it thats all that matters
    can't wait to get mine n do the same!
