Page 21 of 651 FirstFirst ... 1119202122233171121521 ... LastLast
Results 201 to 210 of 6510
Thread: Golf R Observations and Questions
  1. #201
    May 2010
    Brisbane | QLD
    Cool
    Quote Originally Posted by REXman View Post
    Also as for 4wd vs rwd vs fwd,
    I think of it like this. Picture a shopping trolley. A rwd in comparison will be PUSHING it from the rear around the isles. A fwd will be pulling it from the front. Awd will be doing both. Obviously the PULLING method is the most difficult out of the three.
    Also, when launching, a fwd is again the weakest here as the car naturally lifts the nose and plants on the rears, hence why fwd spin so much, they do not contact the tyres to the road as well as the alternatives.
    But having driven GTI myself as well as a type r and jap SSS, I can vouch for these cars being still really good. Its Just they don't touch the rwd and awd's.
    Hey REXman,
    Can i ask why you went for the DSG over the standard manual transmission ?
    Thnaks
  2. #202
    Nov 2009
    I really only see it in such plain terms once torque exceeds grip in a given scenario. So, exiting a tight corner under power in the wet, I'd take an AWD car any day. Of course with the greatest traction on board, it'll power out cleaner and faster than either a front or rear driven equivalent.
    But a constant-radius corner taken on part throttle at high speed? I'd go for whichever car has the lower weight and most balanced weight distribution.
    Yep, agreed, front wheel drive vehicles are at a disadvantage in this respect. I'll also add that your typical experienced performance driver will gravitate to rear drive over front because of the inherent handling traits under power, and because undriven front wheels often yield better steering feedback. You can't really generalise about four wheel drive in this context because there are several types, including the quasi-FWD setups, and they vary dramatically.
    Have to disagree with you there, solely on the basis of generalisation. As I've said above, performance drivers tend to prefer RWD handing characteristics, so manufacturers tend to build serious performance models to satisfy that market. Plenty of the best performance cars in my estimation are RWD or AWD. But I don't base their superiority solely on their driven wheels - only in part. RWD or AWD doesn't in of itself make a car great.
    (I personally would rate plenty of front-drive cars above AWD machines playing in the same segment. Just look at UK Top Gear's recent hot hatch shootout as a good example - a great little FWD won the test.)
  3. #203
    May 2010
    Quote Originally Posted by ccoops79 View Post
    Hey REXman,
    Thnaks
    Hey Ccoops79,
    I think really I bought the DSG because it was something different to try. I test drove it and couldn't argue with the speed of the gear changes. It also made an awesome sound when down changing gears.
    The fact that it's apparently better on fuel (don't care too much) and it's got a higher top speed (like ill ever test that often) than the manual are things I found out after I bought it.
    Someone else also mentioned how useful it is being able to change gears without upsetting the balance of the car as much mid-corner.
    Being in Sydney with the traffic also helped me lean towards my first ever auto-style box.
    If you can drive it but haven't yet bought a manual, I would choose a manual though as they are a pretty sweet and a more easily upgradeable system!
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  4. #204
    Mar 2010
    NSW
    hey rexman have u driven the manual golf R yet? if u have, how does it compare to the wrx manual?
  5. #205
    May 2010
    Quote Originally Posted by oshuyi View Post
    Hey Oshuyl,
    I have driven a manual. I would say for starters the R has a 6 speed not a 5, but you might already know that. Im assuming If you have had a WRX and thats what/why you want to compare.
    I found that the standard set up in the R has almost as short a throw as the WRX with the STI short shift kit installed. But the thing thats better with the VW box is that it was not as notchy to put through the gears, and also easier to select reverse from a forward gear which annoying in the WRX.
    R box is also nice and crisp. Where aa stock WRX box is a bit spongy in comparison.
  6. #206
    May 2010
    Brisbane | QLD
    Hey Oshuyl,
    Hey REXman,
    Thanks for your feedback on the manual R gearbox. I have not been able to locate much information on people's experiences with the manual R so it was very nice to read your perspective, cheers.....
  7. #207
    Feb 2009
    Sydney, Australia
    One of the things I noticed in my 5 minutes in a manual R, is that the clutch travel is much less than in my Polo GTI. The friction point isn't really that far from the floor. I'm not sure if that's a good or bad thing - I guess people would adjust to it.... just an observation
    I'm getting the DSG anyway
  8. #208
    Nov 2006
    Canberra, Australia
    I finally got some quality time behind the wheel of a Golf R on Wednesday. Here's what I discovered -> Drive Thru: Volkswagen Golf R
    MY10 S3 3dr
  9. #209
    Apr 2010
    Melbourne, Australia
    Nice write up Lima.
  10. #210
    May 2010
    Quote Originally Posted by coreying View Post
    Any idea how it compares to the clutch on the GTI? I'm guessing gear throws are just as long?
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
