Independent test on Gtech SS Pro:
Is the G-TECH/Pro SS the World's Ultimate Gauge? | sub5zero.com
Nice times Fab, forget all the negative crap above
I took my R to drags a couple of weeks ago and it had 2500kms, I was a little apprehensive at first but after the first run and how nicely it behaved kinda reassured me that as long as you don't do this every day a launch here and there won't harm things. Also with the Perth motorplex the surface wasn't too smooth and the AWD hooks up nicely with no loss of traction, just drive around the burnout wet patch area and you'll be fine Look forward to your timeslips, be nice to compare them to my stock ones!
Link here http://www.vwwatercooled.org.au/f51/...-20920-12.html
WLF127
my experience with my g-tech is that if its wrong then its a higher number, ive never seen it say a car is quicker than it really is
4 runs in total, twice up against an E46 M3 he was the other driver in Run 3, which was my quickest. The thing I found with the DSG and launch mode is that it is so consistent, the only negative was the night was warm 28 degrees and the car was new. I'll take it for another run when it's cooler and more run in
btw nice times in your sig!
WLF127
