Guys, i have nothing to prove here other than to satisfy myself with what this car is capable of.
Im using a G-Tech Pro SS which is a well proven device for measuring acceleration, & G's ect. Its not an iPhone app.
At the end of the day, if it does low 5's or sub 5 0-100 times i would be happy with the Stage 1 done.
And for the sake of posting the results on the forum for other members info.
My post regarding 4500rpm and no launch control was the truth. I have no reason to B*** S**T. Thats simply what it did.
Im not going to go as far as taking a video of it just to prove myself.
I will be doing the next tests with the use of launch control/sport mode with around 1500k's on the clock.
I guess going by the last few posts that if it does what ever times according to the G-Tech Pro, its not going to be believed anyway (by some)........Rant over...
Ignore the naysayers FLM. I for one are very interested in the results and can completely understand if you are not in the position to video it.
Thanks guys.
I will post the info up as soon as possible, despite the "naysayers".
Cheers.
Volkswagen Golf R
The latest generation Golf R has 188kW and Volkswagen claims it stops the clocks in 5.9 seconds. However, an independent test by the Carsales Network using satellite-based timing equipment returned four runs (two in each direction) of between 5.2 and 5.4 seconds (one person on board, full tank of fuel, 12 degrees outside temperature)!Sub 5 seconds with just an APR stage 1? Starting to look likely!So, I stood on the side of the empty remote flat road in freezing conditions while my colleague set about doing this scientific experiment. And after two runs (one in each direction to account for incline and decline and wind direction) he thought there must have been a mistake... So he repeated the test... The results: four passes between 5.2 and 5.4 seconds each.
As we've said earlier this was at low altitude, 12 degrees and no breeze. In other words: ideal conditions. We tried it later in the day in slightly hotter conditions (16 degrees) after three-quarters of the fuel tank had been emptied, and got a 5.4 second time with no troubles. We were both stunned.
2010 MY10 Golf R (Sold) - 5 Door, DSG, Rising Blue, Leather, ACC, Satnav, Dynadio, Sunroof, MDI, Electric Seat.
2015 MY16 Golf GTI - 5 Door, DSG, Carbon Grey, Leather, Sunroof, DAP.
SteveP in the UK had an R as a loan car, stage 1 tune and catback (not sure what brand tune).
VW GTI MKVI Forum / VW Golf MKVI Forum / VW R20 Forum / VW GTI Forum - Golfmk6.com - View Single Post - Golf R as Loan CarWas given the chance to take it down the 1/4 strip at the GTI International show, run an OK 13.4 seconds 1/4 mile with a 0-60 time of 4.7 seconds.
I just completed two runs.
I will take a pic of the G-Tech runs shortly and post them up.
I could not believe the results but they are why they are.
1st run with launch control at 3000rpm:
4.68
2nd run with launch control and 2500rpm:
4.88
1/4 tank of fuel and no passengers.
What a car. Very happy!!!
Pics to follow of G-Tech.
Edit: pics added
