Results 1 to 6 of 6
Thread: golf r and golf gti- interchangeable parts
    Sep 2009
    seaforth, nsw
    couldnt really find a thread on this, but what parts would be direct bolt ins from the golf r to the golf gti?
    the golf r brakes (front rotors) are slightly larger than the gti, and the calipers have the R logo, but are the calipers actually different?. not sure on the rear setup
    the interior seats of the r would bolt in as well i assume.
    anything else?
    Feb 2009
    Sydney, Australia
    Almost everything dude...
    They're the same car.
    The Golf R front brakes are massively larger than the GTI brakes. The calipers are completely different to account for that large change. The rear brakes are also significantly larger.
    Of course the seats would be swapable. In fact, the standard cloth and the leather seats are the identical design, only differences in materials and logos.
    The engines are different, and so you need to be sure that anything which is designed for one engine but not the other is identified. Obviously there is also the AWD vs FWD and considerations for that.
    Sep 2009
    seaforth, nsw
    I assumed they would be. Good to know for future projects
    Oct 2010
    Alot of the mechanicals (also interior parts exc dash components) are also interchangeable with the MKV GTI's as the Golf R runs essentially the same engine/gearbox, turbo (pirelli edition) & chassis. Easiest way to make sure is by cross referencing part numbers.
    Absolutely loving my Golf R and hearing the Miss' scream when it come's on boost!!
    Dec 2009
    Gold Coast, QLD
    Could there be potential for brake upgrades using OEM R parts for GTIs ?
    Oct 2010
    If the MKV is anything to go by where they upgraded the Gti's with the R32 brakes then there is no reason as to why you couldn't do the same with the MKVI's as they are essentially the same chassis. You could also potentially use brakes from the R36 and Passat CC as they also run a single piston, 345mm disk brake. A quick cross reference of part numbers would determine if the parts are the same as the Golf R.
    ***Correction - Part No. may be different dut to colours, logo's etc although parts may still be interchangeable.***
