Results 1 to 10 of 18
Thread: Golf R flutter or compressor surge (vids included)
    So I have noticed a flutter while in D mode on 40-50% throttle in the lower revs (4th-5th-6th gear).
    The car struggles/revs hang for a few seconds then picks up and goes. APR tune. Please see below.
    Any ideas? Mods in sig.
    GOLF R - CW - MY10 - 3Dr - DSG - LEATHER - SUNROOF - RNS510 - DYNAUDIO - MDI - 19" Black Talladegas
    APR STAGE 2+ - APR Divorced DP - VWR Intake - RS4 Fuel Valve - Neuspeed K04 Turbo Discharge Pipe - BSH Throttle Pipe - HPFP Fuel Pump - SPM FMIC - Hawk Ceramic Pads
    Jun 2011
    sydney
    looks like a tune issue. dumping all boost while shifting into 5th . . .
    Jul 2011
    Good vid!!! Losing boost 100% could be faulty valve?? Check faults. If you decide to replace valve and still there then possibly get it re-flashed back to standard and test. Something is wrong for sure you need to decide which way to find out.
    Change back a gear, don't load such low revs or it will flutter (with any tune, even standard VW software) - remember you have a K04 on that car - The DSG makes it worse as it forces itself up gears (economy mode) where in a manual transmission you would never do it. An open intake makes it more audible (even on a stock car) - we can also reprogram your DSG so it's more pro active and will do a much better job at keeping you in the correct gear
    Jun 2011
    sydney
    its in 'D' mode,
    are you suggesting he drives it in manual mode to hide a tune issue? There is no reason it should flutter under load, as he is not backing off throttle.
    Mar 2008
    Sunshine Coast
    Quote Originally Posted by buzuki View Post
    its in 'D' mode,
    The R will flutter under load, stock !
    I could make mine do it on demand
    As much as I don't intend to defend APR, it happens, stock
    The R and and D mode is stupid. Drive it.
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
    You got me all curious about the DSG reprogram.
    Jun 2011
    Quote Originally Posted by John2204 View Post
    Same here.
    @ APR - Does a DSG tune come with your Stage 1 tune?
    Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
    Jan 2009
    blankedy
    Looks like about 1800rpm.
    How much boost are you expecting below 2k rpm?
    Makes sense you are hearing the airflow whilst the diverter is open.
    I don't see why the DSG would drop you into a gear where the revs are too low for decent power, the joys of trying to get economy from a performance vehicle?
    Pretty sure DSG tuning is separate from ECU tuning.
    Mar 2008
    Sunshine Coast
    No, a number of tuners can modify torque limiters in the DSG via the ECU
