First thing I would do is try and jumpstart the car mate, sounds ALOT like a flat battery.
If that doesn't work, then try turning the headlight switch to the 'on' position and start the car, if that works then you need a new selector unit.
Not sure on what click you're getting, but if you turn the key trying to start it and all dash lights come on but you hear no clicking noises at all (like starter trying to turn) then remove your airbox and check the gearbox earth cable, they sometimes break apart, causing a no start, no crank, no nothing but dash lights
![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
P.S: Your video is set to private so none of us can watch it unless we are signed in.
