Results 1 to 10 of 11
Thread: Golf R - Custom 'Hybrid' Intake
    Dec 2013
    Seems I'm the Goldilocks of intakes. Well not as bad as Lucas_R but getting there I wasn't happy with anything off the shelf and had an idea in mind to make a hybrid intake that gave me both good fuel trims, neat factory-esque looks, and finally an enclosed pod airbox to keep sound down and also feed cold air to the filter while shielding it from engine bay heat. Carbon fibre is very good at this but options are limited unless you make your own and lets be honest, ain't nobody got time to make a carbon fibre airbox. So I made one using the 2 intakes I thought best suited to this task and happened to be able to pick up used by chance - the original VWR intake (pre-fuel trim issues, straight from VWR in the UK not the US market) and the TSI 'Stage 1' Carbonio (which consists of the carbon fibre airbox with a pod inside).
    Fitment on both of these intakes is well known to be not 'plug and play' with the VWR needing some trimming and moving of a couple lines (I played around with different piping configs and couldn't get this to fit nice at all, maybe it's just me) and the TSI was apparently even worse and I'm not sure anyones still using one on an R that isn't running APR Stage 3.
    Below are a few pics of the process I went through today on my day off making it all fit. When I say fit I mean factory, nothing rubbing on anything, nothing jammed up against anything else, just sitting and looking nice.
    First thing you'll notice about the TSI carbonio is some notches and depressions in its surface. These are designed for the TSI engine but that said, some things are pretty damn close and with some tweaks you can make it work.
    First, pop the clamp off and remove this valve, then cut about 8 mm off the hose (keep this, it's recycled later) and remount the valve. I tried initially re-compressing the original clamp but I wasn't happy with the seal and doubted it'd hold 20-25psi and without a boost leak tester made for this car (the one I made for my evo won't fit) I opted for a small worm drive clamp to ensure a good seal.
    The result is it sits in the depression of the box with plenty of clearance
    Next up, after lots of back and forth twisting and playing with different configurations, I decided to use the VWR mount to support the carbonio as without it the whole intake is unsupported and not firm. Where the carbonio mounts behind the grill is just carbon and if the mounting bolts are nipped up tight repeated flexing could stress it to the point of cracking. Different intakes use different support solutions, but the VWR uses a plate with a semicircle cut from it with some u-channel to protect the hard edge and stop it damaging the piping. Thing is, once you mount this a coolant line is right in the way. Seriously I have no idea what they expect you to do with it to get it out of the way while not allowing the line to rub the engine or piping and there's a notch in the carbonio to allow this line to run vertically... So I got creative and broke out the dremel. It's just a plate to hold the upper pipe in place it's not load bearing so I decided it could stand to have some material removed while still doing it's job.
    Much better. Now the coolant line can run up through the notch in the carbonio, then up cleanly through the gap and come up beside the intake piping.
    This shows it clearly
    Took a bit more out of it to give it more lower clearance
    Action shot (may have had a sneaky beer at this point )
    Sits nicely with the retainer in place
    During test fitting the airbox I could see the small coolant line making light contact with the box despite sitting in the carbon fibre notch (close but not quite made for the TFSI...)
    So to position that small diameter coolant line just right, I needed to shorten it to get the bend lower by 8mm or so. Popped the line off and trimmed off the lower ~8mm (keep this, recycled later) then refitted it.
    Perfect.
    To decouple the VWR support bracket I slipped the small coolant line 8mm offcut into the centre of the 8mm valve offcut to make a rubber pad. Place this under the plate then screwed it down as per normal. It lifts the plate slightly creating a slightly better angle to support the intake airbox and also buffers any shocks so that the carbon is less stressed.
    So all done, it sits perfectly and doesn't make contact with anything. All lines run without rubbing and the whole area looks unmolested. Still have room for a catch can too.
    Sat my TTS engine cover in place to see how it'll look (this will need slight trimming to clear the box but that's a job for another day)
    Good install Tim, mind you, you don't need to modify the bracket in any way, You simply use locking clamp pliers on all the water junction pipes & rotate the pipes all counter clockwise to suit. Not everyone has several sets of these clamps at home. do it properly & you dont lose any coolant!
    The shortening of the vac line is correct though!
    Dec 2013
    Thanks Guy. I called you guys up for some advice, James said it needed rotating so I tried that first and just couldn't get enough clearance. The small diameter coolant line was maybe 2mm away from the canister even rotated as far anticlockwise as the line would allow (ie: it was hard up against the side of the cam cover up top). I didn't like the fact it was against the engine and also against the other vac? line just below it. Tried rotating it clockwise too and although that allowed it to clear the canister, it put the small diameter coolant line right where the support bracket was and against the intake pipe. Maybe I wasn't doing it right, I don't know. My ideal was to fit the Carbonio though which I managed to do successfully.
    We run the Cabonio on our stage 3 / 4 GTI / R - its tight & takes a bit of mucking around, but you can keep it clearance. No harm in doing it the way you have anyway!
    Dec 2013
    Yeah I'd seen them on the stage 3's and really liked the design, quality of CF used and the fact it wasn't enormous and took up the whole space in front of the battery area. Being basically sealed to the grill it keeps in cabin noise down to surprisingly low levels too.
    Do you know what filter they run? Oiled or non oiled? It seemed oiled to me but its not new and wouldn't mind either washing it and reoiling or grabbing an Amsoil EAO dry synthetic filter to replace it if I can match the dimensions.
    very lightly oiled filter (similar to K&N), so treat it the same!
    Dec 2013
    Thanks Guy, I'll get a K&N cleaning kit and give it a wash and light re-oil.
    This thing sounds really nice and I think I can feel a stronger midrange, haven't taken it to redline yet but from the graphs the higher the rpm the more gains are achieved with an intake over the stock setup.
    Dec 2013
    Since these EA113 engine are so damn ugly I had to run a cover. No idea why they made the TTRS CEPA motor gorgeous and ours look like bushpigs.
    Had to trim the corner of the TTS engine cover to clear the airbox.
    Finished product
    Dec 2013
    Just an update, very happy with this mod. After a few thousand km nothing is rubbing and it has perfect clearance with everything
    Nov 2013
    GoldenGrove SA
    Need a bit of technical information as in induction noise and fuel trims with the hybrid, I am not sure whether you had a CAI prior to compare the induction noise to.
