Page 5 of 58 FirstFirst ... 345671555 ... LastLast
Results 41 to 50 of 573
Thread: golf R
  1. #41
    Nov 2006
    Canberra, Australia
    Quote Originally Posted by limmy View Post
    tough choice i reckon...if they bring out the scirocco...provided its awd. do you stick with your roots and go the golf...or do you switch to the dark side but you get an arguably fatter and lower car.
    Scirocco for sure.
    MY10 S3 3dr
  2. #42
    Jan 2009
    sunshine coast
    holy sh#t! i think im love,......ep thatll be my next car me thinks. sept i wont be getting it for another 3 years
  3. #43
    Feb 2009
    Mount Gambier, SA
    The plus side about a 24 month wait means its another 24 months get saving.
    Would love to get my hands on one of these in 2011.
  4. #44
    Jan 2009
    sunshine coast
    i read somewhere, that the one in the future r20, will have a modified 2l engine in them. so if its anything like the 2l found in the pirelli edition, expect evan more gains.
  5. #45
    Jan 2008
    Cremorne, Melbourne
    Quote Originally Posted by mikepologti View Post
    As mentioned about a million times, it's pretty certain its the 200kW 2.0T used in the current Audi S3.
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  6. #46
    Nov 2007
    Current information has it as the TTS engine (201kw) not the S3 (188kw). By the time the R20T launches it is more likely to be a new version of the A4/Q5 engine that has many new features.
  7. #47
    Jan 2008
    Cremorne, Melbourne
    yeah sorry thats the one....i knew it was 200kW anyway
  8. #48
    Nov 2007
    The new gen 2.0T motors as now seen 1st in the A4 and Q5 has moved away from the K03/K04 turbo models and are using IHI turbos.
    This coupled with many other internal changes will likely see much more tuneability for the next gen going forward.
    Base power now starts at 155kw/350NM. Chip alone should see around 200kw. Oettinger's 1st pass at it already has it 11kw more than GTI chipped.
    R20T likely (I'm hoping) to get this new gen motor suitably enhanced to make 200+kw.
    Also since the Q5 has a 7 speed DSG hooked up to this new 2.0T it may be the option for the R20T as well. Only problem is both the new A4 and Q5 uses it in longitidunal setups not transverse as was the MK5 R32.
  9. #49
    Jan 2008
    Cremorne, Melbourne
    A good set of coilovers and it would be an absolute track weapon!
    Will the IHI turbo's spool a lot slower, meaning boost on a 3K+. That's the advantage with the KKK turbo's, they were early spooling for boost on earlier and a large power band.
  10. #50
    Nov 2007
    Quote Originally Posted by [-Polo GTI-] View Post
    Not sure, but it makes 350NM from 1500-4200 rmin which indicates an early and very wide powerband with 155kw @ 6000rmin.
