Page 6 of 58 FirstFirst ... 456781656 ... LastLast
Results 51 to 60 of 573
Thread: golf R
  1. #51
    Jan 2008
    Cremorne, Melbourne
    oh ok, which VF code are VAG using in the engines. The Rex STI's use the VF35 to VF43 don't they?
    The VF22 would be a good aftermarket option for the R20T...... they max out at about 400-450hp
    2010 Reflex Silver MK6 Golf GTI
    Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
  2. #52
    Dec 2007
    The new gen 2.0T motors as now seen 1st in the A4 and Q5 has moved away from the K03/K04 turbo models and are using IHI turbos.
    This coupled with many other internal changes will likely see much more tuneability for the next gen going forward.
    Base power now starts at 155kw/350NM. Chip alone should see around 200kw. Oettinger's 1st pass at it already has it 11kw more than GTI chipped.
    R20T likely (I'm hoping) to get this new gen motor suitably enhanced to make 200+kw.
    Also since the Q5 has a 7 speed DSG hooked up to this new 2.0T it may be the option for the R20T as well. Only problem is both the new A4 and Q5 uses it in longitidunal setups not transverse as was the MK5 R32.
    I don't think you will see the Audi DSG transmission in the Golf - as you say, the Audi is north-south configuration, Golf is east-west.
    This means the engine torque will have to be limited to 350nm in the DSG model, since that is the published maximum for the VW box.
    The Nurgurgring Sciroccos were running only 350nm, so it's doubtful VW will deliver more in a production version of the car. I read somewhere that they have fed it 550nm reliably in a couple of test mules, and there are quite a few chipped cars running more than 350 with no apparent problems.
    2008 Blue Graphite GTI DSG with Latte leather. SOLD 4/9/2024
    2023 T-ROC R - Sunroof, Black Pack, Beats Audio
  3. #53
    Sep 2007
    not to get too off topic, but the q5 uses a 7speed dsg with a 3.0 turbo diesel with 500nm stock.. so i'm guessing they have the next generation of dsg with higher torque handling capabilities.
    i think i'd prefer an r20 scirocco.
    87' MK2 GTI
    13' MK7 TDI
  4. #54
    Nov 2007
    Yeah 3.0tdi Q5 has 7speed DSG and 500NM. The next gen DSG have been much improved and is much stronger.
    This tech is now flowing through to base VWs as both the Mk6 Golf and the next Polo will have 7 speed DSGs available. FWD and transverse engines.
    Very likely then will be available in the next GTI and in the R20T. Mine though will be a manual ........
    My reasons for having ordered a R20T is ..... 2.0T and AWD in a VW body.
    Scirrocco will not make it to OZ (and only has 4 seats). Will likely end up driving a 2.0T Tiguan (or a Q5) soon as a replacement for the wife's RAV4 whilst waiting for the R20T to arrive.
  5. #55
    Dec 2007
    Quote Originally Posted by jayjay View Post
    Gentelmen, the Audi 7 speed DSG is not the next gen VW DSG.
    It's a completely different animal which is never likely to be in a VW car, since none of the current VWs can accommodate north-south engine. It's a shame, as the Selectronic is a beautiful design which is able to handle massive torque, much more than 500nm is possible.
    The 7 speed dry clutch DSG that VW is now using was not flow-on tech from the Audi 7 speeder, either. Both were developed independantly, but of course sharing the twin clutch design. VW developed the 7 speeder for smaller engines and cars than the 6 speeder. It's a lot lighter and not as strong and loses the clutch oil supply and cooling circuits.
    Here is a link to a good article with pictures of the new 7 speed S-Tronic. The 6 speed S-Tronic is much the same as the 6 speed VW DSG if not the same.
    http://www.eurocarblog.com/post/677/...-speed-gearbox
    Last edited by gerhard; 05-03-2009 at 10:01 AM. Reason: Insert Link to S-Tronic 7 speed transmission article
  6. #56
    Nov 2007
    Thanks Gerhard, that makes it all much clearer, great info. Pity though .....
    Q5 just climbed a notch on my estimation ladder .....
  7. #57
    Dec 2007
    I spent a lot of time drooling over the Q5 at the show - my pick for the 1800kg beast is the V6 diesel (slightly detuned Touareg motor) but at $72000 it's a big ask when you can get the Touareg for $75000. Extra $3000 for a larger, dual range equipped vehicle? The Touareg would win for me here.
    It seems to go all right with the 2.0 turbo, but I reckon 1800kg is a bit of a haul for the small engine. The wide ratio spread possible in the S-Tronic obviously enables a high ratio for highway cruising and a low 1-2 for launching in traffic, thus giving a good average consumption of 8.5. But I reckon it would be around the 11.0-12.0 around town.
    Beautiful car, though. $59,900 for the 2.0 petrol or diesel, watch out if you tick any options I have the price and specification list in front of me.
    71990 V6 Diesel
    1900 Paint
    1065 Electric Tailgate
    760 Colour Coding
    1915 Electric seats with memory and climate control
    6200 Navigation system
    83830 Phew !! Roll on Tattslotto
  8. #58
    Adelaide hills, SA
    Quote Originally Posted by gerhard View Post
    71990 V6 Diesel
    1900 Paint
    760 Colour Coding
    Did you get the on road price without any option?
  9. #59
    Dec 2007
    No, but it would go something like this in Vic
    59900 rrp
    3000 Dealer delivery ? guessing
    800 Reg
    1725 Stamp duty
    65,425 Approx.
  10. #60
    Canberra
    $ 6,200 Navigation system
    How many people would actually spend that much on a navigation system !! ? Or does it include a great sound system with magic fingers and a guaranteed "happy ending" too ?
