Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 70
Thread: Golf MKVI Air Conditioning
  1. #51
    Apr 2010
    Nedlands, WA
    Quote Originally Posted by G-rig View Post
    you guys have it cranked up too high, mine is always on 20 or 21..
    I think I'd freeze my balls off with the air-con set to 20. (See also: that thread on the Golf being a girl's car... :-p)
    Golf 118 TSI DSG, white with sports pack.
  2. #52
    Nov 2009
    SEQLD
    I usually would have it set to that temp. But last sunday all it would do is blow cold air untill i put it on Hi hot and then it was just way too hot! It had no in between. Had it checked out on Tuesday and there was no faults showing and it has been working ok ever since sunday.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  3. #53
    Feb 2009
    Quote Originally Posted by TDiJetta09 View Post
    Sounds strange..
    In winter i usually go up to 22-23 but don't see how people can have it on 25 (then again i'm fairly hot blooded and haven't really put on a jumper yet this year).
  4. #54
    Apr 2011
    Paddington, QLD
    A/C not cold?
    On my mk6 GTI, I usually set this to 22 degrees. I just got a Lexus IS250 used and notice that the same temperature is much cooler with the A/C. Does anyone else notice their A/C is a bit weak? Or is the lexus just an arctic freeze? My folks Honda Civic is the same - A/C at 22 degrees is way cooler than the GTI.
    Current ride: 2014 Range Rover Evoque 5 Door TD4 Pure | 9 Spd Auto | Fuji White | Black Leather | 19 inch 'Dynamic' Wheels
    Previous rides: MY11.5 Golf GTI 5 door | DSG | Candy White | 18' Detriots | Bluetooth | K&N Air Filter | Dancing Dials (Oh Yeah!)
    | 1989 Porsche 944S2 Coupe| Guards Red| Leather| Sunroof| LSD
  5. #55
    Mar 2008
    Sunshine Coast
    A/C not cold?
    True but the GTI is "hot", the other two just "cold"
    The VW climatronics have never been that good in terms of climate control or temperature accuracy
    8VSS2L/16 E9E9 XG MP SPP1 4ZD 6XK CSC5P with an extra free 10kW
  6. #56
    Apr 2011
    Paddington, QLD
    Still it seems weird based on what I read here that 22 degrees in a VW is and feels so different to 22 degrees in a Lexus/Honda.
    Whilst the VW may sell it as 'constant/variable etc', it seems that it is just a poorer system. Even my old Mercedes had far far better A/C.
  7. #57
    Where does the climate control measure the "temp"? The temp setting is just that... something you can adjust to being comfortable and leave. The climate control should then try its best to maintain whatever "21C" actually means.
  8. #58
    Nov 2009
    Quote Originally Posted by Finance_Analyst View Post
    My previous car (Honda Accord Euro CL9) had exactly the same problems, and for the most part 22 in the Euro felt like 22 in the Golf. Getting these things right is not a given - sensor placement, interior air dynamics, the car's propensity to heat up and cool down quickly (dependent on windows and shapes) can all play a part before you even think about programming the system to pump air at the right temperature.
  9. #59
    Jul 2011
    AU
    You guys are mad. Mine is almost always set to 25oC. Sometimes 24. But then again, this is Qld.
    I've found the A.C. to be very good. But then again I'm not a penguin
  10. #60
    Jul 2011
    AU
    Not too sure where the temp sensor is on the GTI, but in buildings it's fairly common to have the temp sensor in the return air duct. That would also make sense for a car because it would take a broader sample
