It would be strange to be misaligned, seeing as it has been serviced twice and then when also when i was installing the new rotors and pads i checked everything over and didn't notice anything. I could take a pad out and check if there's uneven wear to check for that?
Aside from that, i keep leaning towards it maybe being that the calipers simply aren't grabbing hard enough when stopping and it just slips a little in that last second making the noise. The only reason i can think of for this is that either i need to bleed the brakes or maybe something to do with the master cylinder and there not being enough pressure? The braking doesn't feel bad aside from this noise, you could possibly say it's a little spongey but doesn't seem to be a problem area
Anyone with experience on that?
