Results 1 to 2 of 2
Thread: Golf Mk6 ABS Implaussible when braking to stop on inclining/declining surface
    May 2017
    ID, Jakarta
    DA
    Recently I had this problem....when car is braking (to stop) not on a flat surface (inclining or declining....like when you are going on reverse to enter your slightly elevated parking garage)....it triggers Brake Servo Failure in MID & ABS Implausible signal code shows up in VCDS.
    After leave the car overnight...the code normally goes away.
    But this code will not shows up when you are stopping on traffic light (which usually flat surface).
    The code is not pointing to any of 4 ABS sensors on car.
    Please help me pin point to which area should I start looking for the problem.
    PS : I also monitored Brake Servo Pressure during driving....seems also no changed compared to the condition before problem occurs.
    My car is VW Golf Mk6 1.4 tsi Twincharge engine with 7speed DSG
    Many thanks in advance.
    Regards
    Kent
    Sent from my Redmi Note 8 Pro using Tapatalk
    Google the actual code. It will no doubt lead you down the correct path
