Disconnecting the battery wont work, regardless of how long its disconnected for. I wouldnt connect the + and - terminals together.....recipe for disaster and certainly wont reset the ECU.
Why are you trying to reset it?
Hi,
I want to reset my ECU. I've been advised to disconnect the battery overnight. Then in the morning touch the positive and negative together (no battery involvement) before reconnecting the battery.
Any anyone done this and used a VAG-COM or similar to see if it actually changes (removes data) anything?
It relates to my other thread - How my car takes two seconds to recognise that I've lifted off out of the throttle. Spoke with an old friend that is a mechanic and also supports and distributes Autologic and it was his suggestion.
It would reset the ECU, clear memory and its adaptive learning
I don't have VCDS/VAG-COM . But anything is worth a try.
The other night the car was behaving how it should... for 20 minutes.
It hardware then, the software cannot change.
Having a VCDS lead is really useful with a modern car, if you want to diagnose stuff yourself. You cannot rely on it throwing codes though.
