some GTI's do leak from the sensor at the top of the engine, near the dipstick. Have a look up there around the metal thing with a connector plug into it. Driver's side of the engine. tthe leak then spreads and trickles down to the subframe, whence it leaks onto the tray, and then onto your floor. it's not the seal that's faulty, usually its the fit between the CAS and the engine, and it needs to be replaced. All under warranty, and Insist they clean all traces of oil. watch out though, as per service they require NEW bolts to be used when replacing these things, and they are not the easiest things to get hold of...
More opportunites have been lost from indecision, rather than wrong decision....
