Results 21 to 30 of 34
Thread: Golf GTI Motor Comparison Test
  1. #21
    Mar 2007
    Gold Coast
    Quote Originally Posted by EndlessMKI View Post
    does the MPS have a LSD of any sort like the GTI?
    Mechanical torque biasing diff
  2. #22
    that sort of gap around wakefield is quite significant.
    is turn8 the last turn or second last turn?
    but then again theres no point comparing unless both cars are on the same tyres.
    MPS3 has a LSD
    and WTF about the tyres? You test cars as they come from the manufacturer.
  3. #23
    Nov 2007
    Interestingly to note is that at the end of the main straight the GTI was 3km/h faster .... this is a tribute to the DSG and how it put the power down coming out of the last corner ....
    It is also here where you'd expect the MPS' superior power to shine through .... which it did NOT ...
    SO I'd comfortably believe the ESP was responsible for the deficits around the other corners and ultimately then the slower lap time ....
  4. #24
    Feb 2009
    Sydney, Australia
    Which may be true Sharkie. But if you can't turn it off, then that really doesn't matter then does it?
  5. #25
    Nov 2006
    Georges Hall
    Ah lap times...a lot like Dyno figures.
    Back in '05 Master Bates did 1.14.7 at Wakey in a GTI.
    Luffy did 1.15.29 in a GT[not GTI] in '07
    But in '08 Luffy twice ran a MPS.First time was 1.12.81,then 1.13.00
    John Boston drove both cars on the track in the last test,resulting in a 1.14.4 for the MPS,and 1.15.2 for the GTI.
    Lap times can vary by a second around Wakefield just with different weather conditions-even different time of the day.
    So the MPS is quicker on the track,but the GTI is the better all-round drive.
    I've driven enough of these cars on the track to satisfy me that's the case.
    I've also seen enough of Luffy's driving of these cars to convince me he gets the most out of them of anyone I've seen.
    Len
  6. #26
    Nov 2005
    Quote Originally Posted by pologti18t View Post
    MPS3 has a LSD
    was simply outlining other considerations that should be taken into account if you want a better understanding of true performance.
    Cheers,
    Will.
    MY16 MKVIIR - Option: Folded rear seats mode.
    MKI....#14....lost count.
  7. #27
    Nov 2005
    If their the corners I'm thinking of, those corners are the ones that dip away from the apex which would cause the ESP to kick in. Specially the last corner.
    it's a real shame you can't turn it completely off though because you could be easily caught mid corner while the car is in full flight and you would not be able to adjust your direction using more throttle and less steering correction.
  8. #28
    Cheers,
    Will.
    But its not... manufacturers select a number of tyres they fit as standard to maximise what they see as important re: handling, grip, noise etc.
    Switching to a "control" tyre could ultimately upset the handling of the car and decrease its handling capabilities.
  9. #29
    Nov 2005
    Awesome! now I see where your coming from.
  10. #30
    Oct 2009
    sydney NSW
    It has been touched on before....the two cars (gti and mps) were tested on different days dry and drying track. Compare apples with apples i say!
    I have a current UK car magazine on my coffee table. CAR PCOTY 2009 ISSUE 568 (WWW.CARMAGAZINE.CO.UK).
    I have tried to download the link to the article for the performance car of the year (PCOTY) but ran into a brick wall...yes I had to part with some money!!!!!
    Anyway there were 5 "hot hatches" on test.
    The two elements of the test that I was interested in were the 0-62mph and lap times (Rockingham circuit UK).
    VW GOLF GTI: 6.9sec/1:42.85
    MAZDA MPS: 6.1 sec/1:42.00
    FORD FOCUS RS: 5.9sec/1:40.09
    SUBARU IMPREZA 330S: 4.8sec/1:39.51
    HONDA CIVIC TYPE R MUGEN: 6.0sec/1:39.48
    The GTI was chosen as the PCOTY hot hatch winner. It was slowest of the group but was the best of the above cars to drive in the real world.
    Also notice the lap times of the MPS and GTI are very close.
    On a different note:..I have just clocked up 1000km on the GTI!...I checked the tyre pressures at the servo tonight...they were at 42psi!...does that seem a little high?
    Happy motoring!
    David
