Page 8 of 25 FirstFirst ... 67891018 ... LastLast
Results 71 to 80 of 244
Thread: Golf GTI: the good, the bad, the weird...and appreciation thread
  1. #71
    Dec 2009
    Sydney NSW
    Quote Originally Posted by picard2bridge View Post
    flappa said:
    Has anyone else experienced this?
    Yes, I have to admit some days it seems that way and also the outside temperature seems to make a difference as well, ie seems more responsive on colder days,than on hotter days but I think that's a normal characteristic for turbos. (yes this is my first turbo).
    mk VI GTI, manual, reflex silver, basic
  2. #72
    Apr 2010
    Nedlands, WA
    I've had exactly the same thought, and for a while there I was worried that there was something wrong with my GTI. First week or so, my head was repeatedly jerking backwards against the headrest, but now no more. And I miss it.
    But I'm sure there's not a change in the actual performance, it's just that I am used to it now, and probably a little more controlled with the right foot as well.
    You definitely adjust to driving a fast car and begin to think of it as normal. My 118TSI is slower than my previous car, and it still feels to me like I have to rev it pretty high if I want it moving in a hurry. But every time I drive another (more 'normal') car, I'm reminded that compared to most of what's on the road, even the Golf TSI is pretty quick.
    mfl's comment about turbo'd cars being slower in hot weather might also be relevant. This was really noticeable in my old Ford XR5 which was very much designed for European conditions: both the engine and the air conditioner were happier when it was below 30 degrees outside. Lots of people on the XR5 forums had fitted larger intercoolers to help make up for that. I'm assuming that the Golf GTI isn't quite so bad because I haven't seen anyone here mentioning doing that - and I'm sure that if it was a problem, a company like APR would step up to provide an aftermarket solution.
    Golf 118 TSI DSG, white with sports pack.
  3. #73
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by cameronp View Post
    *cough* You mean like this? *cough*
  4. #74
    May 2010
    Yes hot air is not good for turbo cars trying to achieve optimal power.
    Cold air = More oxygen = more boost.
    Cold morning's will see (easy if you have a boost gauge) that the car in question will boost considerably higher and quicker than on a hot day.
    Once you have driven your new GTI/R/TSI etc on a scalding hot Sydney/Queensland day (SLUG!).. and then you give the car a hit on a crisp, cold morning.. awesome stuff!
    I remember my friend and I when we were younger (10 years ago) took his 180SX to the snow.. insane difference. Had to be at least 10 atw kw..
    2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
    2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
  5. #75
    May 2010
    Here's a weird one I've noticed: it seems to take a bit for the steering wheel mounted audio controls to start working after starting the car. Took at least 20 seconds before the arrow keys to change track started to work...same for the volume.
    What's weird is that there are occasions where it starts working right away....there are other times when it takes some time.
    Scirocco R - Candy White / DSG / Panoramic Roof / RNS510
    Mods - HPA ECU & DSG Stage 2 / VWR Racing Intake / Akrapovic Slip-On Titanium Tips / Milltek DP / HPA Mounts / Superpro LCA / H&R Sport Springs / VMR V710 19x8.5 / Michelin PSS 255-35
  6. #76
    Jan 2008
    Quote Originally Posted by ktrianta View Post
    If you re-enter the car after it's been stopped for under 20 minutes they will work straight away.
    If you open the door and take your time getting in they will work generally a few seconds after starting.
    And if you open the door and start the car straight away (after it's been sitting for >20 minutes) it will take a while for the headunit to startup and the steering wheel controls to operate. The controls on the front of the headunit work all the time.
  7. #77
    Apr 2010
    Have never experienced noticeable delay with the steering wheel controls - I only wish that they would still work after I stop the engine after a trip.
  8. #78
    Jul 2010
    The Good:
    - left mounted indicator stalk (yes, that's right!) - this way I get to keep my right hand at the wheels at all time since the wiper, headlights are all automatic. Car is DSG so there is no need to shift back and forth between indicator stalk and gearshift.
    - DSG is quiet and smooth in traffic, while still allowing some decent performance when I give it the boot
    - deep low exhaust growl, pop and crackle when revmatch downshift is fun.
    The Not so Good:
    - no bixenon standard - I think they should for a car of this 'calibre'
    - no rearview camera standard - if you have kids you'll know why it's quite important to have one
    - 4 door's window control felt was mounted a bit too high, I constantly reached rear window control when trying to lower front window
    The Weird
    - had a corolla hatchback wanted to race, wtf?
    - could still spin the wheel quite considerably even with ESP on... I thought it would prevent that?
  9. #79
    Quote Originally Posted by rs73 View Post
    The Weird
    ESP might be semi-off but traction control is still on
    MKV GTI Pirelli
  10. #80
    Jul 2010
    another weird thing... accelerator is floor mounted but brake is top mounted? why didn't they go all the way eg all floor mounted?
