The old dilemma of if/when to tune. Basically this is the way I see it:
1) You change your cars over often and definitely prior to warranty expiring/60k major service and/or before the tyres/brakes wear out. You can probably afford to fix the car should you break it. Go for it!!!!
2) You keep your car 3-5 years and change it over reasonably regularly
and you want to tune it then you're probably best off tuning it relatively early in it's life and enjoying it for the maximum amount of time. If you wait until your warranty is over then you'll only have the tune on for a (relatively) short time. If something breaks you'll be up for the repairs anyway... so you may as well have put the tune on earlier and enjoy it for longer
3) If you plan to keep the car longer term (10 years/200,000km) then for sure you can wait until the warranty expires. You'll still have quite a few years of enjoyment/value out of the tune and it will probably prolong the life of the car by not tuning it too early in it's life. If you're planning on keeping it long term I'd definitely recommend minor service intervals (oil/filter change every 7,500km) and you'll still be up for the repair bill should you break it
