Results 1 to 4 of 4
Thread: Golf 77TSI Turbo(?) issue - Surge then no power
    Mar 2012
    Unhappy Golf 77TSI Turbo(?) issue - Surge then no power
    Hey Guys.
    I've just had a weird issue with (I believe) the turbo on my 2012 Golf 77TSI Manual.
    I was pulling out of my driveway, and received a sudden and unexpected surge of power, after which the car was very sluggish and had no power. Flooring it in second at 2000rpm only gained speed slowly, whereas it would normally knock your hat off. It still drove relatively smoothly - just not quickly.
    Turning off the ignition for a few minutes and driving off again appeared to resolve the issue - the car was responding normally.
    It seemed like an issue with the Turbo - I suspect it overboosted, and then went into limp home mode(?) - Although there was no "Check Engine" light or Error Codes reported.
    Running my VIN through the VW maintenance website shows it's due for service campaign 24v9, which I believe involves fitting a shim to the wastegate - I suspect this is potentially the culprit?
    Given my lack of mechanical knowledge, I wanted to
    a) Check if my diagnosis is in the ballpark? What other issues could potentially cause this?
    b) Work out if my car is likely to be safe to drive for a few days until I can get it to the service center? (i.e. I'm not going to do more damage if I continue to drive it?)
    Dec 2008
    Sydney/Canberra
    The shim is to rectify a small rattle that some owners have taken exception to.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2009
    I may not have THE answer, but i have had this issue on my car several times and it was put down to a faulty sensor in the accelerator pedal. Vw have replaced mine 4 times. Sometimes i got the engine warning light, other times not.
    I would say it is worth taking the car to vw to have it looked at. It is obviously not normal.
    When it happened in my car it felt like a naturally aspirated 1.4 !
    Skoda Octavia Mk3
    (sold) Golf Mark 6 Comfortline 118
    (sold) Golf Mark5 Comfortline Manual 2.0 FSI
    Jun 2011
    sydney
    get it in for the 24V9, your problem should be solved. Rectifies incorrect adjustment of actuator which can lead to performance complaints which could lead to limp mode
