Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 153
Thread: Golf 118TSI vs. 103TDI
  1. #121
    Feb 2009
    Sydney, Australia
    Thanks logger.
    So with the APR Stage I, the 118TSI is about where the MK6 Golf GTI is at standard, although without the composure that the GTI has doing it.
    The old little Polo GTI with Stage I is just a touch quicker than both... that is until you then place the APR Stage I on the MK6 Golf GTI and it then leaves both behind.
    The log that you're able to produce is pretty cool... now you just need to borrow someone's Golf GTI to produce the same log and compare hehe
  2. #122
    Manly - Sydney
    Agreed fantastic stat's and a good read, Cheers logger.
    Stoney!
    6 Sp Manual 118 TSi
    Colour: United Grey
    Build Date: August 09 Delivery Date: 16th Oct 09
    ODO at last fill: 2555km
    Avg Fuel Cons at last fill: 8.6
  3. #123
    Jan 2010
    Condell Park, NSW
    Quote Originally Posted by logger View Post
    Heres the log..
    Monday,14,June,2010,12:40:34:29097
    Control Module Part Number: 03C 906 027 BA Component and/or Version: MED17.5.5 G 5860
    Metric units
    0 to 100 km/h: 6.8
    400m: 15.4, @115 km/h
    90-120 km/h: 3.6
    200 meters: 9.7 , @120 km/h
    US Units
    0 to 60 mph: 6.6
    1/4 mile: 15.4 , @71 mph
    60-90 mph:
    660 feet: 9.8 , @75 mph
    Nice work, Logger...
    One point though - is this log 100% correct? Why is the speed at 400m slower than at 200m?
    Regards,
    - Anthony
    VW Tiguan 110TSI Life | Tungsten Silver
  4. #124
    Feb 2009
    Sydney, Australia
    Quote Originally Posted by hoi polloi View Post
    Regards,
    - Anthony
    The first one was a 0 to 100kph run, and then what speed it was doing after 400m.
    The next one was a 90 to 120kph rolling run, and then what speed it was doing after 200m.
  5. #125
    Apr 2010
    Nedlands, WA
    Quote Originally Posted by coreying View Post
    That still doesn't sound right. Looking at the long table of times vs velocities at the end, I'd surmise that all of the figures are from the same run, but that logger backed off the accelerator a bit before the 300m mark. Extrapolating a bit by eye, I'd expect to see a realistic 400m trap speed in the 140-150 km/h range, probably closer to 150.
    And if this log is anywhere near accurate, that's damned impressive performance from the chipped 1.4TSI.
    Golf 118 TSI DSG, white with sports pack.
  6. #126
    Aug 2009
    Melbourne, Vic
    nothing to say
  7. #127
    Apr 2010
    Nedlands, WA
    Interestingly with the stock tune (APR stage1 disabled), 8.0 and 8.2 seconds although I only did two runs in that config. No slip, shudder or TC light in stock tune. Just Smooooth. Whereas in stage1 with TC active you get the TC light and intervention every time when it is active.
    Keep in mind I only have the bog standard skinny tyres too.
    So if I'm understanding right, you were testing that on the standard tune by taking your foot of the brake and then immediately flooring it without switching off TC, and there was no axle tramp, no flashing TC light? That surprises me because in my TSI with the stock tune (and SC2S4 recall applied) and sports pack (wider tyres than yours) I've accidentally spun the wheels and had the traction control intervene when taking off in a hurry.
  8. #128
    Aug 2009
    Melbourne, Vic
    Not interested any more.
  9. #129
    Jan 2008
    Sunshine Coast
    For the record, I will log my TDI the same way, but have a best of 7.5 to 100k and a 15.5 400m using VCDS in the past. Pretty much stock. Also, having test driven all three in MK V manual form back to back, twice or more each over 4 hours, give me a GTI anyday for traffic light derby. Can't comment on DSG.
  10. #130
    Adelaide hills, SA
    Yeah, get back on topic?
