Now you have described the idle speed in more detail, thats not the plugs imo. More like an injector with a wrongly directed output pattern due to blockage. Had one with me to look at like that some 12 months ago and the problem was a bad injector spray pattern.
Give away was the injector in No.1 cylinder was spraying clean the No.1 plug so it looked like it had been in a spark plug cleaning machine when it was extracted. Idle was lumpy as you describe. There were also tell-tale spray wash areas on the piston crown. Question is, did they do all the injectors or has it been an unfortunate repeat (dirty fuel?). Or have you got burnt valves due to the earlier poor injector spray patterns they replaced???
New plugs or old. Given what I have just said, I think they are not the source of the rough engine. Don't know what your driving regime is ie. like mine or open road a lot of the time. If SOC as above yes new, if open road, try re-gapping and see how it goes but note the insulators should be cleaner than my photograph above.
VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
