Page 70 of 139 FirstFirst ... 2060686970717280120 ... LastLast
Results 691 to 700 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #691
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by logger View Post
    No one has done a 118TSI cylinder recently have they?
    Does Feb/March this year count as recent? The two rebuilds below date from then.
    Quote Originally Posted by dood View Post
    Be afraid. Be very afraid.
    exact problem I had. It got worse. Then the light on the dash came on (something about exhaust). it got worse. I took it in and they found loss of compression on cylinder one. It was booked in for a full check but before I got there it got a lot worse (jerky ride, loss of power). Warning came on to take the car straight to the service centre. Turned out to be the dreaded fuel injector - cracked piston issue. I finally got the car back last week after about a month in the garage.
    Quote Originally Posted by Feng View Post
    Count me in as another unfortunate statistic. Just got my 118TSI back from the workshop today, it's had its timing belt, pistons, water pump, gaskets and other assorted bits and bolts replaced under warranty. We thought it was a minor issue when it was vibrating oddly at idle, turns out it was something major. And this comes after the DSG had its clutch pack replaced last year due to it hestitating and shuddering!
    This thread has been an eye opener, I wish I knew about the bad combination before I bought the car last year. I'm now considering cutting my losses and selling it while it still has some value. Might get something Japanese but there aren't many alternatives which compare to the interior and handling of the Golf. I might hold out till the new Mazda 3 comes out or even consider the Lexus CT200h if the budget can stretch that far!
    Resident grumpy old fart
  2. #692
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by kaanage View Post
    Yeah I guess they would.
    On the other hand depends when those cars were build. Should have asked how many cyclinder failures with engines built after the "fix" was implemented. Ie is it truly a fix for newer or replaced engines never exposed to the pre fix regime.
  3. #693
    Oct 2010
    Melbourne, VIC
    Feng later posted that his car was a Dec 2010 build which would seem to be after this service campaign was instigated. The multitude of continuing Polo 6R GTi complaints (since that uses a warmed up version of the same engine) is also worrying but then some (most?) people have no problems at all.
  4. #694
    Aug 2009
    Melbourne, Vic
    Been away from these forums for quite a while so did not read about the Polo 6R GTi issues. Surely it is not the same issue is it?
    Wouldn't you love to know how many early MK6 twin-charger engines were replaced or rebuild as a % of those on the road at the time. Anecdotally is wasn't just a handful.
  5. #695
    Feb 2013
    northern Perth WA
    In further response to Logger, me and apparently 4 others, in early March one week in Wangara. Plus another soul being told the news when mine went back in in April for the DSG replacement. So 118TSI cylinder fails are still happening in WA, at least for those with low kms. To give Wangara VW and VWA their due, there was no quibbling about warranty for me for both cylinder and DSG woes, and the Europcar loaner Passat was very nice transport.
    Missed this: mine was late 2010, sold June 2011, but not door stickered until after the engine failed, so presumably not factory fixed before delivery. The late April fail was a 2009 model Golf.
    And there are more than 50 documented fails just in these forums, so a lot of grumpies like me but a lot of fails nonetheless
  6. #696
    Nov 2009
    Curious Stelex, have you recounted the problems you had with your car to the Dept of Infrastructure & Transport or your States Fair Trading mob?
    I have. I also asked them for the assistance, called the ACCC and lodged a formal complaint but to no avail. These bodies are toothless tigers. Essentially, they advised me that I need to seek remedy from VW and if they don't come to the party I can lodge complaint with them, which I did. What happened? Nothing, they told me that the best course of action is to sue VW for lost time and reduced value of vehicle, make it under (IIRC) $7,500 and take it through the small claims court. That's where it (their advice) ended.
    I spoke to a lawyer who is a good friend of my best friend and who specialises in this sort of disputes. She advised me that the thing is winnable but it will take forever and that I might need to remortgage the house if I want to go ahead.
    In the end I have purchased extended warranty. The car is leased, so I couldn't sell it until the lease expires (4 years) unless I incurr serious losses. As I wasn't keen on having the car without a warranty for one single day after all that happened to it, I had to get warranty myself.
    The dealer where I purchased the car, and never serviced there, was very sympathetic and very apologetic and sold me the extended warranty for $1,670, he said it was 'at cost'. At the time I couldn't find it anywhere under $2,300.
    In early 1990s I spent 5 years of my life in Germany and had Golf I, Golf Ia, Golf II, Passat Wagon Diesel and Jetta II and really enjoyed each one of them, with no issues at all, even though they were all 10+ year old cars. Then I bought this piece of junk, I don't know what happened meanwhile, they cocked it up big time.
    What now? Waiting 29th November, the car will be on sale the moment the sun goes up.
    Last month I purchased a new Honda Accord Euro and enjoying it no end ... fingers crossed Golf is now driven by my wife, doing just minimum kilometres, work, shops, garage. I just don't trust it anymore, don't trust VW at all.
    Never again.
    Never.
    Not. Ever. Again.
    (well, I guess it shows how frustrated I am
  7. #697
    Apr 2013
    you know that selling now and paying out the lease early makes very little difference to your actual "outgoing"
    say for example the car is "going" to be worth $15K in November in 6 months time and is now worth $21K as a payout. look at your lease payments, they will be $1000 a month. ie: you are paying down the difference between the payout value today and the final figure.
    your outgoing will be identical whether you wait or just bite the bullet now.
  8. #698
    Dec 2007
    GLENHUNTLEY,VICTORIA
    Stelex,I also drive a Honda Accord Euro after 4 new VWs ,my last one a Jetta 5.
    You will see a big diffirence in build quality and reliability.
    Honda dealers have been way better to deal with,and I am sure you will be hooked for life now...
  9. #699
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Stelex View Post
    Thanks Stelex. If nothing else contacting them might have added to the numbers of dissatisfied consumers.
  10. #700
    Jan 2010
    State of Denial
    Failures still occurring in VW's ancestral home where they have good fuel. Clearly a mechanical design/quality control issue and consistent with VW's strategy of explaining global failures as being unique to individual markets. The global brands like VW need to realise that information no longer respects national boundaries these days, so they can stop patronising us.
    Google Translate
    I chickened out and sold my 118TSI - I was going to make it a long termer as our second car. Unfortunately with the 7spd DSG I bought the problem engine and gearbox combo although my vehicle did have other niggling issues. Still kicking myself I didnt buy the 2.0Tdi manual for the same price.
    A big minus for me was the long wait for parts to arrive whenever something needed to be fixed under warranty (eg 3wks for suspension components).
    I pick up my replacement car next week so this will likely be my last post. This forum has been a good source of info and entertainment, so thank-you everyone.
    2018 Tiguan 110TSI Comfortline + DAP
