To remove the spark plugs, the coil packs have to be removed using the Coil Pack Removal Tool T10094A. What ever is the equivalent of £35 UK prices to the A$.
Without it, it is very difficult as the first time, the Coil Packs will held in with thick solid grease used for moisture protection which makes extraction very difficult. It is not advisable to try and pry the Coil Packs out as they will be damaged. Secondly No.1 cylinder Coil Pack is very awkward to remove without the correct extraction tool T10094A or equivalent 3rd party tool.
Plugs just need a long reach extension bar on the standard small plug socket. 25Nm tightening torque.
Transfer as much of the grease as you can to the new plugs. Aids coil pack extraction as well as moisture blocking. Its very expensive high temperature white grease - G052 141 A2 (20g tube).
VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
