Thanks Prise. Just got my car done. I grabbed some "before" logs including 12 parameters including the Lambda as you suggested. Post update I was initially snookered, because the reflash changes the reported ECU program from mark G to mark BA. This meant VCDS could not do the advanced measuring values. So I have just corrected my label files to reflect this. It is all working again and I can see everything I want to. Nothing obvious but I have only done a 5 minute real quick after mod log. So there is not enough info to really compare. Cursory look shows max loads and max EGTs are still the same. Car feels gutless but this is most prob because I disabled the APR tune 24 hours ago to test, pre flash. So anything will feel gutless by comaprison. About to go for a 200km drive and will try to do some better logs. Will report back.
