Page 25 of 139 FirstFirst ... 1523242526273575125 ... LastLast
Results 241 to 250 of 1381
Thread: Golf 118 TSI Engine Failures and Service Campaign 24S4
  1. #241
    Jan 2010
    State of Denial
    Quote Originally Posted by logger View Post
    Can you take a quick peek at tsi.txt and tell me what group will give Air Fuel Ratio?
    You want to get the lambda value. A lambda of 1.0 means the mixture is stoichometric (~14.7:1), less than 1 is rich, more than 1 is lean. Sometimes it is displayed as an equivalence ratio which is the inverse. The easy way to work out what is being displayed is to check and see if the reading goes above or below 1.0 at high load and RPM. If it goes down below 1.0 it will be lambda, ie getting richer.
    I would start with:
    031,1,Lambda Control,Bank 1 (actual)
    031,2,Lambda Control,Bank 1 (specified)
    This should give you the target value and achieved value. If pulling a raw sensor reading then you should take the one before the catalyst which would normally be sensor 1.
    In combination with the RPM, manifold pressure and ignitiion timing info you have already identified it should give a pretty good indication if any significant changes to maps have been made. Theres some other interesting data there on the knock sensing but its going to be impossible to interpret the readings unless we had access to the interface spec for the sensor.
    I assume that you will wait until the coolant temperature has stabilised and try to repeat the test at a equivalent ambient temperature.
  2. #242
    Aug 2009
    Melbourne, Vic
    Thanks Prise. Just got my car done. I grabbed some "before" logs including 12 parameters including the Lambda as you suggested. Post update I was initially snookered, because the reflash changes the reported ECU program from mark G to mark BA. This meant VCDS could not do the advanced measuring values. So I have just corrected my label files to reflect this. It is all working again and I can see everything I want to. Nothing obvious but I have only done a 5 minute real quick after mod log. So there is not enough info to really compare. Cursory look shows max loads and max EGTs are still the same. Car feels gutless but this is most prob because I disabled the APR tune 24 hours ago to test, pre flash. So anything will feel gutless by comaprison. About to go for a 200km drive and will try to do some better logs. Will report back.
  3. #243
    Jun 2006
    Sunshine Coast
    How Many KMs? 26570
    Do you mainly do a lot of short trips? No 38 km to work most days
    Do you mainly do fewer longer trips? No weekend mainly 250 kms runs
    Do you alway drive in a gentle manner? No
    Do you flog the car and give it a bit of a hiding from time to time? Not really
    Do you only use 98Ron fuel? Yes
    What is your car build date?[/QUOTE] Dec 08
    Have had the supercharger clutch replaced and the DSG Mechatronic unit replaced.
    2018 Skoda Superb TDI
    2010 Skoda Superb TDI
    2009 Golf VI 118 TSI
    2006 Multivan TDI SOLD
  4. #244
    Nov 2009
    Rowville, Vic
    Ok, all this technical talk is baffling me a bit... the question is...
    after having this update done, are we guaranteed that our engines won't blow up?
    I (and I'm sure many others), have taken a big risk choosing this car - one that we thought was a quality machine... (well, on paper anyway)
    Am I going to regret this in a few years time?
    ~Nic~
    Deep Black Mark VI Comfortline 118 tsi - manual/sports pack, MDI
  5. #245
    Feb 2010
    VIC
    Quote Originally Posted by nicandlance View Post
    Shouldn't you be speaking to VW about this? I understand your concerns, but no one here is in the right position to give you any guarantees with this particular issue.
  6. #246
    Nov 2009
    SEQLD
    VW are not going to tell us the truth even if we asked them.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
  7. #247
    Jan 2010
    State of Denial
    Nic, recalls and SW updates are unfotunately a fact of car ownership these days. Every one of the four new cars I've owned previously has had some type of defect that has neede to be rectified and my last car also had a SW update to correct problems with an incorrectly calibrated sensor. This didn't stop them being dependable transport dopwn the track after they had been 'de-bugged'. In this day of internet and instant communication we get to hear about the 1 in a 1000 case where a mechanical failure occurred whereas 10 years ago we would have been blissfully unaware. Ultimately you are relying on the knowledge and backing of one of the worlds largest car makers that has already made over a million TSI engines.
  8. #248
    Feb 2009
    Sydney, Australia
    There were 2 recalls on my Toyota Echo before I switched over to VW. My brother's Ford Territory has a recall on it too. Not sure there is any car company that hasn't had recalls.
  9. #249
    Mar 2010
    Witness Protection
    Quote Originally Posted by coreying View Post
    I can't believe you admitted to having once owned an Echo.....
  10. #250
    Feb 2009
    Sydney, Australia
    Yeah, it was a blue Sportivo model. Got it when it first came out at the end of 2001. Would have loved to have got something better, but it was hard as someone in early 20's with a mortage already. Was a great car though. Could fit 6'3"+ friends in the back. I moved my 42" Plasma in it a few times. I also sold it for over 50% of it's new purchase price after 7 years! lol
